Date/Time: Fri, 31 Jan 2025 20:12:59 +0000
Cqg + SC data , No premium to cash/indices
View Count: 1200
[2019-06-02 15:26:25]
User329962 - Posts: 8
i am using cqg amp and signed for SC data, CME plus S&p indices, if im connected to cqg and SC data, im not able to get data for indices and premium ("symbol is unknown"). If i turn off cqg im getting the data. Whats the problem here? thanks
[2019-06-02 16:47:55]
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2019-06-02 17:10:23]
I've sent the message log data for analysis
[2019-06-02 17:47:04]
Tell us one of the symbols you have an issue with and we will check that.
[2019-06-02 17:55:13]
ESM19-$INX and one of the S&P indices lets say $SRCS
[2019-06-03 17:32:31]
Let's just take this one symbol at a time. You should be getting real-time data at this time for ESM19-$INX. Please confirm.
The log does not indicate any problem. Refer to:
SC Data - All Services | Restarting real-time data updates for symbol: ESM19-$INX -> ESM19-$INX | 2019-06-02 18:04:35.053
[2019-06-03 18:35:58]
Symbol Error - ESM19-$INX is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2019-06-03
Im still getting "symbol is unknown", was using just sierra chart data without cqg, worked fine.
[2019-06-03 19:04:15]
That message can be safely ignored. It will clear from the chart after about 30 seconds. As long as that chart is updating in real time, this is what counts.
That error relates to the security definition data for the symbol not being known by CQG.
