Date/Time: Fri, 31 Jan 2025 20:53:56 +0000
Replay menu unreachable / partially off screen
View Count: 1046
[2019-06-01 16:37:27] |
User1990 - Posts: 49 |
Hi, My replay menu somehow has been moved partially off the screen that I can't seem to reach its top to move it or adjust it. I am wondering if you can please help me with this issue. I've attached an image below for your reference. Thanks so much for your help. http://www.sierrachart.com/image.php?Image=1559406990253.png Best Regards, Elaine |
[2019-06-01 22:51:19] |
You just need to select Window >> Reset Windows to reposition it to the default location.
