Date/Time: Fri, 31 Jan 2025 20:51:58 +0000
Trade copying
View Count: 1251
[2019-06-01 08:55:12] |
samual sprat - Posts: 343 |
hi. I noticed one of the features of the Sierra data service and routing is the ability to have more than one broker account available per instance/chart. I'm using amp only ATM but would like to add a Rithmic account and copy trades from amp to rithmic. Do I need the Sierra routing service to achieve this? is there a way to use a different amount of contacts for each broker yet or is quantity replicated exactly too? This page implies this isn't possible yet... Order Allocation to Trade Accounts Thanks S |
[2019-06-01 23:28:42] |
copy trades from amp to rithmic. This inherently does not make sense. Your account with AMP must be using a backend service like Rithmic or CQG or anything else they support like TT. Copying of trades can only be among the accounts associated with the logged in user name. So if your Rithmic username has multiple accounts on it, you can do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-01 23:28:57
