Date/Time: Fri, 31 Jan 2025 20:56:30 +0000
ACSIL: sc.GetOrderFillEntry , result of TradePositionQuantity is allways NULL
View Count: 813
[2019-05-31 20:36:10] |
TedMar - Posts: 190 |
in example of SC ACSIL howto get working OrderID/FilledPrice in ReplayMode (Sim) | Post: 166232 i added the OrderFillData.TradePositionQuantity in s_SCOrderFillData OrderFillData structure , but result is allways 0 Is them a Bug or wrong pull method? |
[2019-06-02 03:54:38] |
There is definitely no problem with this. Use the study GetOrderFillEntryExample to test this and the source code is provided. If the problem relates to the particular external trading service you are using, we cannot help with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
