Date/Time: Fri, 31 Jan 2025 20:58:04 +0000
Version: 1926 32-bit -Control Bar Button Images Have Disappeared
View Count: 799
[2019-05-31 19:23:23] |
User804714 - Posts: 4 |
Hello, Version: 1926 32-bit I noticed after the update to the latest version that the Control Bar button images are gone. How do we get them back? The BMP images are not defined to set the images to the buttons. Thanks |
[2019-06-01 02:13:33] |
This is resolved in prerelease 1927. Update to the prerelease following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
