Date/Time: Fri, 31 Jan 2025 20:44:13 +0000
Bid Ask Depth Bars not persistent
View Count: 690
[2019-05-31 14:13:51]
Tooth Fairy - Posts: 79
Things that make the bid/ask depth bar study not persistent i.e. reset the study to display only the last 10min or so instead of the duration SC is on (limited by max source data setting in this case Times & Sales): Switching from simulation mode to live & vice versa, Show Order fills, Clear Trade Simulation Order Data. There are probably some more but that's all I can get at this point. Some are annoying but bearable but destroying the persistence of the study when taking a look at order fills is very nasty. Please take a look into this "feature" and kindly remove it.
Version 1927
Date Time Of Last Edit: 2019-05-31 14:16:54
[2019-05-31 15:22:26]
The internal implementation of the Bid and Ask Depth Bars study is going to change and this will no longer be an issue. Allow one to two months.
Date Time Of Last Edit: 2019-05-31 15:22:38
