Date/Time: Fri, 31 Jan 2025 20:56:41 +0000
limitation of coding to 128conditions
View Count: 560
[2019-05-31 13:29:59] |
User512854 - Posts: 24 |
in coding, when programming new strategy, the file DLL is limited to 128 conditions only? please clarify if we can exceed
[2019-05-31 13:39:40] |
This does not make sense. And what constitutes a "condition"? There is no limitation. Really we are not clear what you are referring to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-31 13:39:50
