Date/Time: Thu, 06 Feb 2025 04:13:27 +0000
Deleting CQG account number in trade activity log
View Count: 896
[2019-05-31 12:57:47] |
patrader - Posts: 92 |
I am running two separate instances of Sierra with two separate CQG Fix trading logins with two different brokers. When I set up the second instance I copied various files over from the first instance. Now I am seeing, in the second instance, a CQG account number in the trade activity log that actually relates to the CQG login on the first instance. Is there any way to eliminate this CQG account number from the second instance (to get rid of it from the pull-down account option in trade activity) because it is basically a defunct account in the second instance with it not being paired to the correct login. Thanks.
[2019-05-31 16:00:28] |
Refer to this section here to clear trade activity for a particular account: Trade Activity Log: Clearing Trade Activity Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-13 14:37:48] |
I'm revisiting this topic after changing computers. I am still seeing two "old" CQG account numbers in the pulldown menu for accounts in the Trade Activity window.. I don't want them as pull-down options for live accounts anymore because those CQG connections no longer exist (I am using the SC TT routing service today). It's not a question of deleting trade activity for the defunct CQG connections. I just want to eliminate them as options for live accounts in the Trade Activity window. How do I do that?
[2020-04-14 21:17:22] |
First thing to do is follow these instructions: Select File >> Disconnect. Select Global Settings >> Convert Trade Activity Format. Select File >> Connect to Data Feed. This procedure only needs to be done once. And then follow the instructions here: Trade Activity Log: Clearing Trade Activity Data Through Files But this is going to remove the activity altogether but what you can do instead is just put the files in another folder so you do not see the accounts listed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-14 21:18:24
