Date/Time: Fri, 31 Jan 2025 20:58:41 +0000
Ver1926
View Count: 648
[2019-05-31 11:16:13] |
User821468 - Posts: 84 |
Upon upgrading to 1926, my control bar symbols reverted to letter names vx symbols.Is there an easy way to convert symbol names back to symbols?they are far better to recognize than letter names. Thanks
[2019-05-31 13:07:29] |
The default is scalable text but we have put back the images for now in version 1927. Update with Help >> Download Prerelease.
[2019-05-31 16:37:06] |
1927 prerelease Much better Thanyou
