Date/Time: Fri, 31 Jan 2025 21:02:59 +0000
Copying market depth data
View Count: 642
[2019-05-31 06:19:25] |
samual sprat - Posts: 343 |
Hi, I've got 2 computers. One is my main trading platform and the other is a media centre. I normally run my trading pc 24x5 and the media centre 24x7. Is it possible to a capture market depth data on my media pc and then copy those files over to my trading pc in the morning so I can turn the trading pc off anytime and not miss data? Thanks S |
[2019-05-31 11:32:39] |
ticinotrader - Posts: 401 |
Hi, You can simply copy and move the files from the SC\Data\MarketDepthData folder to any other SC copy. It works for me without any issue. Your mediacenter should run a copy of Sierra properly set to collect depth files. Hope this helps.
[2019-05-31 16:43:36] |
Top stuff. Thanks bud!
[2019-06-01 16:02:46] |
Yes the information given in post #2 is valid.
