Date/Time: Fri, 31 Jan 2025 21:08:39 +0000
market depth c_ACSILDepthBars.GetLastDominantSide vs. MarketDepthHistoricalGraph
View Count: 725
[2019-05-30 18:33:17] |
onnb - Posts: 662 |
Working with the market depth api, ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars): GetLastDominantSide I have a level that is returning BSE_UNDEFINED I can visually see this level painted and colored with MarketDepthHistoricalGraph So I understand from that you determine that that level belongs a side. Does GetLastDominantSide logic differ from what MarketDepthHistoricalGraph uses? If "yes" what is the proper way to determine if a price level belongs to bid or ask so that it is exactly same as MarketDepthHistoricalGraph? |
[2019-05-31 18:09:44] |
Jeffrey - Posts: 2203 |
The Market Depth Historical Graph simply defaults to the ask side in any case where the last bid quantity is not greater.
[2019-06-01 22:55:34] |
The documentation will be updated with this information.
