Date/Time: Fri, 31 Jan 2025 20:18:30 +0000
Enable live trading in single chart within Chartbook
View Count: 1038
[2019-05-30 13:48:36] |
User23815 - Posts: 210 |
Within a single Chartbook I have multiple charts open for the ES. I want to track ES for the signals but trade the new micro. Is there a way to enable live trading only on the micro chart? Or to disable trading on the ES charts? Thanks
[2019-05-30 14:18:16] |
This can be done by using this setting (Trade and Current Quote Symbol): Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-30 14:18:21
