Date/Time: Mon, 05 Oct 2026 12:46:11 +0000
how do i find out when another user (who has permission) is accessing my account?
View Count: 1129
| [2019-05-30 12:55:57] |
| 4646ed - Posts: 231 |
| [2019-05-30 14:19:28] |
Do you mean your Sierra Chart account? We will see if we can provide some further information on this in the account control panel.
| [2019-05-31 14:45:37] |
Yes, my SC account. I gave them permission to access it from their own computer to help me with some programming problems.
Date Time Of Last Edit: 2019-05-31 14:47:19
| [2019-05-31 15:23:46] |
Ok we are going to add to the user control panel page the number of logged in systems which will give you an indication of this.
| [2019-06-13 06:35:52] |
OK, I see that's been added. Is there any way a log of the usage dates and times for all systems being used could be accessed? I need to find out if someone who i have contracted to do some work for me is actually doing the work.
| [2019-06-13 11:38:12] |
Yes it is here: https://www.sierrachart.com/UserControlPanel.php#AccountDetails Allowed Systems: 0 out of a total of 2 system(s) are currently being used.
We will see what else can be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-06-18 06:58:08] |
I'm not sure I've been clear enough. A history of usage dates and times for all systems is possible?
