Date/Time: Fri, 31 Jan 2025 20:14:17 +0000
Trade and Current Quote Symbol question
View Count: 1145
[2019-05-30 10:41:19] |
User950781 - Posts: 5 |
Hey i have an issue with the trade and current quote symbol, i'm using IB datafeed and i want to chart the DAX 25 and trade on the DAX mini 5, i have set the Symbol to be the DAX 25 and the trade and current quote symbol to the DAX mini and it works fine like that clicking apply and continuing but when i change to chart some other symbol from quoteboard and come back to this DAX 25 it removes the Trade and current quote symbol that was set to be the DAX mini completly leaving it to only chart and trade the DAX 25
[2019-05-30 14:25:31] |
What you need to do in this case is set that particular Trade and Current Quote Symbol for the full-size DAX symbol in the Global Symbol Settings: Global Symbol Settings The Global Symbol Settings window has changed in newer versions of Sierra Chart. The documentation is relative to the old window but there is not a whole lot of difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-30 14:26:14
[2019-05-30 15:28:08] |
ohh yeah i see on the Global symbol settings has the trade/quote Symbol spot, changing the symbol there solved the issue. Thanks
