Date/Time: Fri, 31 Jan 2025 20:16:25 +0000
Volume per bar - wrong candles
View Count: 1040
[2019-05-30 10:38:46]
User710679 - Posts: 43
Hi there, i am plotting a chart using "volume per bar" feature, with 10k per bar.
when i compare this chart with other platforms (i.e. ninja or OEC), it does not plot the same candles (open , close , high and low). I am using the same data feed for all the platforms and i have the same candles in the other 2 platforms.
do you know what i might be doing wrong in sierra?
thanks a lot!
David
imagevolume per bar.png / V - Attached On 2019-05-30 10:37:22 UTC - Size: 114.67 KB - 271 views
[2019-05-30 14:27:41]
Refer to:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
The most important thing you need to do is to make sure that New Bar at Session Start is enabled and that the Session Start Time matches.
Date Time Of Last Edit: 2019-05-30 14:28:02
