Date/Time: Fri, 31 Jan 2025 19:52:40 +0000
64 Bit V 32 Bit Audio drivers Not a problem - For your info only
View Count: 633
[2019-05-30 07:17:53]
User360283 - Posts: 508
I recently switched to the 64-bit version.
Previously I was having audio alert problems - constant crackling and weak volume
Driver updates and other techniquest did not solve the problem.
Switching to the 64-bit version and the audio problems disappeared.
Thought Sierra should know.
Best regards
[2019-05-30 14:28:32]
This does not mean anything to us. This is going to be a system-level issue.
