Date/Time: Fri, 31 Jan 2025 19:48:35 +0000
CQG connection message log question
View Count: 588
[2019-05-30 06:31:12] |
onnb - Posts: 662 |
I am looking at the message log, user is using CQG Web. See below. At 17:39:49 the socket is closed and then a new connection is logged at 18:49 (I made these rows in bold below) Does that mean anything is wrong? Does it mean that SC was not connected for an hour? Received Date-time from server. Delay adjusted UTC Date-time: 2019-05-29 22:39:48.044. Round-trip delay: 00:00:00.340 | 2019-05-29 17:39:48.986 Computer time to server time difference: 00:00:00.943 | 2019-05-29 17:39:48.986 Successfully set the system Date-time to: 2019-05-29 22:39:48.044 UTC. | 2019-05-29 17:39:48.988 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. | 2019-05-29 17:39:49.242 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2019-05-29 17:39:49.410 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Closed. | 2019-05-29 17:39:49.410 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2019-05-29 18:39:47.833 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Connecting to IP: 46.4.97.203. | 2019-05-29 18:39:47.833 Received Date-time from server. Delay adjusted UTC Date-time: 2019-05-29 23:39:48.512. Round-trip delay: 00:00:00.320 | 2019-05-29 18:39:48.473 Computer time to server time difference: 00:00:00.039 | 2019-05-29 18:39:48.473 Successfully set the system Date-time to: 2019-05-29 23:39:48.512 UTC. | 2019-05-29 18:39:48.474 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close. | 2019-05-29 18:39:49.257 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2019-05-29 18:39:49.413 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Closed. | 2019-05-29 18:39:49.413 Date Time Of Last Edit: 2019-05-30 06:31:29
[2019-05-30 13:31:21] |
These messages are not related to the CQG connection.
