Date/Time: Fri, 31 Jan 2025 20:13:50 +0000
ACSIL: sc.GetTradePositionForSymbolAndAccount function member AveragePrice not works
View Count: 1114
[2019-05-29 22:39:39] |
TedMar - Posts: 190 |
i tryed for example of chart with study sc.GetTradePosition and sc.GetTradePositionForSymbolAndAccount result , Quantity works with both , but AveragePrice with sc.GetTradePosition only |
[2019-05-30 04:53:36] |
We will resolve this in the next version but it is not always going to be set. It will be accurate for Trade Simulation Mode but for non-simulated trading it may or may not be set. It is only more assured to be accurate with this particular service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-30 06:47:37] |
but this is essential to find out AveragePrice for other symbol, or u have other idea?by sc.GetOrderForSymbolAndAccountByIndex and sc.GetOrderByOrderID with s_SCTradeOrder is posible check Order status only. If fact dont know how i can check for Other Symbol Order Fills with open Position status and FillAvarage. Any Idea? Mybe is posible to check Fill by Fill , or Last In first Out Fill matching status to find which allready filled Orders are Not calculate in Open Positions and FillAvarage? |
[2019-05-30 12:24:14] |
ForgivingComputers.com - Posts: 992 |
int TradeOrderResult;
double OrderID1FillPrice; s_SCTradeOrder TradeOrder1; TradeOrderResult = sc.GetOrderByOrderID(OrderID1, TradeOrder1); if (TradeOrder1.OrderStatusCode == SCT_OSC_FILLED) { OrderID1FillPrice = (double) TradeOrder1.AvgFillPrice; } |
[2019-05-30 13:32:48] |
@bradh OrderID1FillPrice = (double) TradeOrder1.AvgFillPrice; Date Time Of Last Edit: 2019-05-30 13:34:23
