Date/Time: Fri, 31 Jan 2025 19:56:08 +0000
Show Order Fills
View Count: 1874
[2019-05-29 20:36:22]
User355173 - Posts: 9
Hello, I have been trying to find the way to show the order fill on the chart but I would like to visualize only the lines and not the box with the price and quantity of the fill. Basically I would like to just show on the chart the lines and the triangle of the fills. Is it possible?
[2019-05-30 01:20:29]
Refer to the following setting and the items below it related to Order Fills. You would just need to turn off all the options in order to only have the fill triangle:
Global Trade Settings Windows: Display Fill Text (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
