Date/Time: Fri, 31 Jan 2025 20:11:46 +0000
Stop order not being filled.
View Count: 590
[2019-05-29 16:07:48] |
User319394 - Posts: 2 |
Earlier today I had a buy order with a bracket set on the nasdaq micro if it dropped to a certain number and my internet ended up dropping and by the time it came back the buy had been filled but my bracket was gone. This is obviously a huge issue because I don't have any downside protection. Do these bracket orders not go to the server of my broker if I'm not logged into my account?
[2019-05-30 05:01:09] |
No they do not in the case of CQG. The way this works is documented here: Attached Orders: General Management of Attached Orders For full server-side bracket functionality you need to use this service here: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
