Date/Time: Fri, 31 Jan 2025 20:12:40 +0000
200 Tick Chart
View Count: 618
[2019-05-29 13:58:40] |
User94606 - Posts: 327 |
Is this the correct setting (see attached screenshot) for creating a 200 tick chart?
200 Tick Chart.jpg / V - Attached On 2019-05-29 13:58:26 UTC - Size: 128.11 KB - 308 views |
[2019-05-29 14:20:22] |
Yes.
