Date/Time: Fri, 31 Jan 2025 21:09:31 +0000
ACSIL Use as Trade Only Symbol
View Count: 823
[2019-05-29 08:01:46] |
Trade Nice - Posts: 75 |
The Trade and Current Quote in Chart Setting can be set with ACSIL 'sc.TradeAndCurrentQuoteSymbol' but what is the ACSIL setting for 'Use as Trade Only Symbol'? Thank you Date Time Of Last Edit: 2019-05-30 17:49:38
[2019-05-30 17:50:49] |
Any response?
[2019-05-30 23:51:18] |
Yes this is not something that we are going to be adding.
[2019-05-31 06:18:27] |
What is the effect of having the "Use as Trade Only Symbol" ticked but also have the "Trade and Current Quote Symbol" empty. Would the trade then happen with the symbol in the "Symbol" box? |
