Date/Time: Fri, 31 Jan 2025 20:18:51 +0000
Ho to send trail order
View Count: 554
[2019-05-29 06:44:14] |
User479048 - Posts: 19 |
I am not able to send Order type : TRAIL from sierra to IB. i tried sending using attached order by selecting trailing stop, trailing stop limit and others but it always go in ib as STP or STP LMT Order type. please help on how can i send TRAIL order from sierra to ib. |
[2019-05-29 15:08:33] |
This is not supported.
