Date/Time: Wed, 09 Sep 2026 07:43:54 +0000
Show Market Data Columns
View Count: 2012
| [2019-05-28 22:42:47] |
| User103219 - Posts: 8 |
For the life of me I cannot figure out where to adjust Font and Color settings for the Show Market Data Columns. Can you please point me in the right direction. Thank you!
| [2019-05-29 18:05:44] |
| John - SC Support - Posts: 47806 |
Global Settings >> Graphics Settings, then find the particular item you want to adjust. Note that the items that are part of the Chart DOM start with "Chart DOM" in the list. Refer to the following documentation: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: ChartDOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-05-29 19:41:48] |
This is also documented here: Chart Trading and the Chart DOM: Trade DOM and Chart DOM Font and Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-10-22 16:23:29] |
| EdCarp - Posts: 25 |
Neither of these answers are specific - there are more than a hundred items to choose from. Can someone perhaps be a bit more specific?? This is SPECIFICALLY for the "Show Market Data Columns", not anything else. Thanks! |
| [2019-10-22 22:29:50] |
We assume that you want to change the color of the Bid and Ask depth in the Buy and Sell columns. These items are found at the following links: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Ask Depth Quantities Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Bid Depth Quantities But keep in mind, the option for "Show Market Data Columns" will display whatever columns have been selected to be displayed in Trade >> Customize Chart/Trade DOM Columns. Therefore, there could be any number of other options that you were asking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
