Date/Time: Thu, 17 Sep 2026 14:56:53 +0000
[User Discussion] - cqg connection
View Count: 1371
[2019-05-28 20:22:44]
User729700 - Posts: 10
Hi -- i was disconnected from sierra charts/cqg about an hour ago and have been unable to reconnect--my message log is below--please advise--thanks
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-28 20:57:43.267
Reading Internal Order ID file. | 2019-05-28 20:57:44.031
Reading Trade Orders file. | 2019-05-28 20:57:44.488
Reading Trade Positions file. | 2019-05-28 20:57:44.613
Reading Account Balance file. | 2019-05-28 20:57:44.719
UDPListener (840). Port 22903 | Listening on UDP port 22903. | 2019-05-28 20:57:44.790
Software version: 1921 64-bit | 2019-05-28 20:57:44.790
Enabled for: Advanced Features. | 2019-05-28 20:57:44.790
Enabled for: Advanced Features 2. | 2019-05-28 20:57:44.790
Enabled for: Sierra Chart Historical Data Service. | 2019-05-28 20:57:44.790
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-05-28 20:57:44.790
Current selected Data/Trading service: CQG WebAPI | 2019-05-28 20:57:44.790
Custom symbol settings values: enabled | 2019-05-28 20:57:44.790
Chart Update Interval: 500 | 2019-05-28 20:57:44.790
Intraday Data Storage Time Unit: 0 | 2019-05-28 20:57:44.790
Data/Trade Service Settings automatically set. | 2019-05-28 20:57:44.790
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2019-05-28 20:57:44.790
2019-05-28 20:57:44 Local computer time | 2019-05-28 20:57:44.790
2019-05-28 19:57:44 Local computer time in UTC | 2019-05-28 20:57:44.790
2019-05-28 20:57:44 Local computer time in SC Time Zone | 2019-05-28 20:57:44.790
2019-05-28 19:57:39 Server time in UTC | 2019-05-28 20:57:44.790
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-05-28 20:57:44.790
Program path: C:\SierraChart\ | 2019-05-28 20:57:44.790
Data Files path: C:\SierraChart\Data\ | 2019-05-28 20:57:44.790
OS Version Number: 6.1 | 2019-05-28 20:57:44.790
Locale Setting: C | 2019-05-28 20:57:44.790
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-05-28 20:57:45.230
Created the DTC Protocol server. | 2019-05-28 20:57:45.265
DTC Protocol Server listening on port 11099. | 2019-05-28 20:57:45.266
Created the DTC Protocol historical data server. | 2019-05-28 20:57:45.266
HD Server Manager | Listening on port 11098 | 2019-05-28 20:57:45.266
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-05-28 20:57:45.266
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-05-28 20:57:45.254
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-05-28 20:57:45.255
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-05-28 20:57:45.261
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-28 20:57:45.261
Received 5 login tokens. | 2019-05-28 20:57:45.426
Symbol settings MD5 received. Request ID: 1. | 2019-05-28 20:57:45.436
Symbol settings are up-to-date for cqg. | 2019-05-28 20:57:45.436
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-05-28 20:57:45.685
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-05-28 20:57:45.685
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-05-28 20:57:45.711
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-05-28 20:57:45.711
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-05-28 20:57:45.711
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-05-28 20:57:45.711
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:57:47.284
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-05-28 20:57:47.284
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-28 20:57:47.713
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-28 20:57:47.739
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-28 20:57:47.739
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:57:50.516
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:57:50.516
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:57:50.521
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:57:50.521
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:57:51.598 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:57:51.604
CQG WebAPI | WebSocket closed. | 2019-05-28 20:57:51.604
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:57:51.598
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:57:51.611
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:51.611
CQG WebAPI | Disconnected. | 2019-05-28 20:57:51.613
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:51.613
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:57:54.623
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:57:54.623
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:57:54.624
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:57:54.624
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:57:55.675 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:57:55.676
CQG WebAPI | WebSocket closed. | 2019-05-28 20:57:55.676
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:57:55.676
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:55.676
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:57:55.675
CQG WebAPI | Disconnected. | 2019-05-28 20:57:55.684
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:55.684
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:57:58.694
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:57:58.694
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:57:58.695
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:57:58.695
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:57:59.732 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:57:59.736
CQG WebAPI | WebSocket closed. | 2019-05-28 20:57:59.736
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:57:59.736
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:59.736
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:57:59.732
CQG WebAPI | Disconnected. | 2019-05-28 20:57:59.740
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:57:59.740
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:02.751
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:02.751
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:02.751
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:02.751
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:03.787 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:03.788
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:03.788
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:03.788
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:03.788
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:03.787
CQG WebAPI | Disconnected. | 2019-05-28 20:58:03.796
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:03.796
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:06.806
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:06.806
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:06.807
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:06.807
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:07.843 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:07.844
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:07.844
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:07.844
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:07.844
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:07.843
CQG WebAPI | Disconnected. | 2019-05-28 20:58:07.852
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:07.852
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:10.862
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:10.862
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:10.863
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:10.863
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:11.899 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:11.900
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:11.900
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:11.900
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:11.900
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:11.899
CQG WebAPI | Disconnected. | 2019-05-28 20:58:11.908
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:11.908
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:14.918
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:14.918
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:14.919
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:14.919
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:15.954 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:15.955
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:15.955
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:15.955
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:15.955
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:15.954
CQG WebAPI | Disconnected. | 2019-05-28 20:58:15.964
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:15.964
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:18.974
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:18.974
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:18.975
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:18.975
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:20.015 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:20.015
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:20.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:20.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:20.015
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:20.015
CQG WebAPI | Disconnected. | 2019-05-28 20:58:20.020
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:20.020
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:23.030
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:23.030
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:23.031
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:23.031
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:24.067 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:24.068
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:24.068
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:24.068
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:24.068
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:24.067
CQG WebAPI | Disconnected. | 2019-05-28 20:58:24.076
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:24.076
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:27.086
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:27.086
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:27.103
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:27.103
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:28.140 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:28.140
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:28.140
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:28.140
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:28.140
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:28.140
CQG WebAPI | Disconnected. | 2019-05-28 20:58:28.147
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:28.147
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:31.158
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:31.158
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:31.159
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:31.159
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:32.195 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:32.196
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:32.196
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:32.196
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:32.196
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:32.195
CQG WebAPI | Disconnected. | 2019-05-28 20:58:32.203
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:32.203
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:35.214
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:35.214
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:35.215
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:35.215
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:36.251 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:36.251
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:36.251
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:36.251
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:36.251
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:36.251
CQG WebAPI | Disconnected. | 2019-05-28 20:58:36.259
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:36.259
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:39.270
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:39.270
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:39.271
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:39.271
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:40.307 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:40.307
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:40.307
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:40.307
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:40.307
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:40.307
CQG WebAPI | Disconnected. | 2019-05-28 20:58:40.315
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:40.315
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:43.326
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:43.326
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:43.327
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:43.327
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:44.363 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:44.363
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:44.363
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:44.363
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:44.363
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:44.363
CQG WebAPI | Disconnected. | 2019-05-28 20:58:44.371
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:44.371
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:47.382
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:47.382
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:47.383
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:47.383
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:48.420 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:48.420
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:48.420
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:48.420
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:48.420
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:48.420
CQG WebAPI | Disconnected. | 2019-05-28 20:58:48.427
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:48.427
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:51.438
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:51.438
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:51.439
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:51.439
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:52.474 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:52.475
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:52.475
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:52.475
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:52.475
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:52.474
CQG WebAPI | Disconnected. | 2019-05-28 20:58:52.483
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:52.483
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:55.494
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:55.494
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:55.495
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:55.495
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:58:56.531 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:58:56.531
CQG WebAPI | WebSocket closed. | 2019-05-28 20:58:56.531
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:58:56.531
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:56.531
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:58:56.531
CQG WebAPI | Disconnected. | 2019-05-28 20:58:56.539
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:58:56.539
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:58:59.550
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:58:59.550
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:58:59.551
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:58:59.551
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:00.587 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:00.587
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:00.587
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:00.587
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:00.587
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:00.587
CQG WebAPI | Disconnected. | 2019-05-28 20:59:00.595
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:00.595
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:03.606
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:03.606
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:03.607
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:03.607
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:04.642 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:04.643
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:04.643
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:04.643
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:04.643
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:04.643
CQG WebAPI | Disconnected. | 2019-05-28 20:59:04.651
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:04.651
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:07.662
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:07.662
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:07.663
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:07.663
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:08.699 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:08.700
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:08.700
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:08.700
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:08.700
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:08.699
CQG WebAPI | Disconnected. | 2019-05-28 20:59:08.707
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:08.707
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:11.719
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:11.719
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:11.719
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:11.719
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:12.755 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:12.756
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:12.756
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:12.756
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:12.756
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:12.755
CQG WebAPI | Disconnected. | 2019-05-28 20:59:12.764
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:12.764
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:15.775
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:15.775
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:15.775
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:15.775
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:16.810 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:16.812
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:16.812
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:16.812
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:16.812
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:16.810
CQG WebAPI | Disconnected. | 2019-05-28 20:59:16.820
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:16.820
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:19.830
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:19.830
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:19.831
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:19.831
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:20.883 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:20.884
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:20.884
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:20.884
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:20.884
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:20.883
CQG WebAPI | Disconnected. | 2019-05-28 20:59:20.892
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:20.892
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:23.901
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:23.901
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:23.902
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:23.902
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:24.940 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:24.941
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:24.941
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:24.941
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:24.941
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:24.940
CQG WebAPI | Disconnected. | 2019-05-28 20:59:24.947
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:24.947
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:27.957
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:27.957
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:27.958
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:27.958
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:28.994 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:28.995
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:28.995
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:28.995
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:28.995
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:28.994
CQG WebAPI | Disconnected. | 2019-05-28 20:59:29.003
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:29.003
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:32.013
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:32.013
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:32.014
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:32.014
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:33.050 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:33.052
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:33.052
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:33.052
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:33.052
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:33.050
CQG WebAPI | Disconnected. | 2019-05-28 20:59:33.059
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:33.059
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:36.069
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:36.069
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:36.070
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:36.070
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:37.114 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:37.123
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:37.123
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:37.123
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:37.123
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:37.122
CQG WebAPI | Disconnected. | 2019-05-28 20:59:37.130
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:37.130
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:40.141
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:40.141
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:40.142
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:40.143
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:41.172 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:41.180
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:41.180
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:41.180
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:41.172
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:41.180
CQG WebAPI | Disconnected. | 2019-05-28 20:59:41.186
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:41.186
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:44.197
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:44.197
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:44.198
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:44.198
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:45.233 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:45.234
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:45.234
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:45.234
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:45.234
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:45.233
CQG WebAPI | Disconnected. | 2019-05-28 20:59:45.242
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:45.242
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:48.253
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:48.253
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:48.254
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:48.254
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:49.289 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:49.290
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:49.290
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:49.290
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:49.290
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:49.289
CQG WebAPI | Disconnected. | 2019-05-28 20:59:49.298
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:49.298
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:52.309
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:52.309
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:52.310
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:52.310
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:53.345 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:53.346
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:53.346
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:53.346
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:53.346
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:53.345
CQG WebAPI | Disconnected. | 2019-05-28 20:59:53.354
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:53.354
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 20:59:56.365
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 20:59:56.365
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 20:59:56.366
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 20:59:56.366
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 20:59:57.402 *
CQG WebSocket | WebSocket closed. | 2019-05-28 20:59:57.402
CQG WebAPI | WebSocket closed. | 2019-05-28 20:59:57.402
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 20:59:57.402
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:57.403
CQG WebSocket socket (1) | Closed. | 2019-05-28 20:59:57.402
CQG WebAPI | Disconnected. | 2019-05-28 20:59:57.410
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 20:59:57.410
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:00.421
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:00.421
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:00.422
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:00.422
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:01.460 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:01.461
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:01.461
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:01.461
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:01.461
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:01.460
CQG WebAPI | Disconnected. | 2019-05-28 21:00:01.467
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:01.467
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:04.477
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:04.477
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:04.478
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:04.478
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:05.514 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:05.514
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:05.514
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:05.514
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:05.514
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:05.514
CQG WebAPI | Disconnected. | 2019-05-28 21:00:05.522
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:05.522
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:08.532
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:08.532
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:08.534
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:08.534
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:09.586 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:09.587
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:09.587
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:09.587
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:09.587
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:09.586
CQG WebAPI | Disconnected. | 2019-05-28 21:00:09.594
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:09.594
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:12.605
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:12.605
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:12.606
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:12.606
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:13.642 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:13.642
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:13.642
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:13.642
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:13.642
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:13.642
CQG WebAPI | Disconnected. | 2019-05-28 21:00:13.650
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:13.650
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:16.661
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:16.661
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:16.662
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:16.662
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:17.700 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:17.701
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:17.701
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:17.701
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:17.701
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:17.700
CQG WebAPI | Disconnected. | 2019-05-28 21:00:17.706
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:17.706
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:20.717
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:20.717
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:20.718
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:20.718
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:21.754 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:21.754
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:21.754
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:21.754
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:21.754
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:21.754
CQG WebAPI | Disconnected. | 2019-05-28 21:00:21.762
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:21.762
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:24.773
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:24.773
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:24.774
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:24.774
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:25.810 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:25.810
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:25.810
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:25.810
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:25.810
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:25.810
CQG WebAPI | Disconnected. | 2019-05-28 21:00:25.818
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:25.818
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:28.829
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:28.829
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:28.830
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:28.830
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:29.866 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:29.866
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:29.866
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:29.866
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:29.866
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:29.866
CQG WebAPI | Disconnected. | 2019-05-28 21:00:29.874
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:29.874
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:32.884
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:32.884
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:32.886
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:32.886
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:33.922 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:33.922
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:33.922
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:33.922
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:33.922
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:33.922
CQG WebAPI | Disconnected. | 2019-05-28 21:00:33.930
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:33.930
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:36.940
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:36.940
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:36.942
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:36.942
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:37.994 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:37.993
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:37.993
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:37.993
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:37.993
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:37.994
CQG WebAPI | Disconnected. | 2019-05-28 21:00:38.002
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:38.002
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:41.012
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:41.012
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:41.013
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:41.013
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:42.049 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:42.050
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:42.050
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:42.050
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:42.050
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:42.049
CQG WebAPI | Disconnected. | 2019-05-28 21:00:42.058
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:42.058
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:45.068
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:45.068
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:45.069
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:45.069
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:46.105 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:46.106
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:46.106
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:46.106
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:46.106
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:46.105
CQG WebAPI | Disconnected. | 2019-05-28 21:00:46.114
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:46.114
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:49.124
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:49.124
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:49.125
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:49.125
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:50.161 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:50.162
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:50.162
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:50.162
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:50.162
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:50.161
CQG WebAPI | Disconnected. | 2019-05-28 21:00:50.170
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:50.170
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:53.180
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:53.180
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:53.181
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:53.181
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:54.220 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:54.221
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:54.221
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:54.221
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:54.221
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:54.220
CQG WebAPI | Disconnected. | 2019-05-28 21:00:54.226
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:54.226
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:00:57.236
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:00:57.236
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:00:57.237
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:00:57.237
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:00:58.274 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:00:58.275
CQG WebAPI | WebSocket closed. | 2019-05-28 21:00:58.275
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:00:58.275
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:58.275
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:00:58.275
CQG WebAPI | Disconnected. | 2019-05-28 21:00:58.282
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:00:58.282
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:01:01.292
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:01:01.292
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:01:01.293
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:01:01.293
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:01:02.329 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:01:02.330
CQG WebAPI | WebSocket closed. | 2019-05-28 21:01:02.330
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:01:02.330
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:02.330
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:01:02.329
CQG WebAPI | Disconnected. | 2019-05-28 21:01:02.338
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:02.338
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:01:05.348
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:01:05.348
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:01:05.349
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:01:05.349
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:01:06.385 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:01:06.386
CQG WebAPI | WebSocket closed. | 2019-05-28 21:01:06.386
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:01:06.386
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:06.386
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:01:06.385
CQG WebAPI | Disconnected. | 2019-05-28 21:01:06.394
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:06.394
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:01:09.404
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:01:09.404
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:01:09.405
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:01:09.405
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:01:10.441 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:01:10.442
CQG WebAPI | WebSocket closed. | 2019-05-28 21:01:10.442
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:01:10.442
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:10.442
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:01:10.441
CQG WebAPI | Disconnected. | 2019-05-28 21:01:10.450
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:01:10.450
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:03:10.448
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:03:10.448
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:03:10.461
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:03:10.461
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:03:11.497 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:03:11.499
CQG WebAPI | WebSocket closed. | 2019-05-28 21:03:11.499
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:03:11.499
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:03:11.499
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:03:11.497
CQG WebAPI | Disconnected. | 2019-05-28 21:03:11.506
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:03:11.506
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:05:11.517
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:05:11.517
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:05:11.517
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:05:11.517
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:05:12.553 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:05:12.554
CQG WebAPI | WebSocket closed. | 2019-05-28 21:05:12.554
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:05:12.554
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:05:12.554
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:05:12.553
CQG WebAPI | Disconnected. | 2019-05-28 21:05:12.561
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:05:12.561
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:07:12.564
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:07:12.564
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:07:12.659
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:07:12.659
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:07:13.688 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:07:13.688
CQG WebAPI | WebSocket closed. | 2019-05-28 21:07:13.688
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:07:13.688
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:07:13.688
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:07:13.688
CQG WebAPI | Disconnected. | 2019-05-28 21:07:13.696
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:07:13.696
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:09:13.699
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:09:13.699
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:09:13.701
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:09:13.701
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:09:14.757 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:09:14.758
CQG WebAPI | WebSocket closed. | 2019-05-28 21:09:14.758
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:09:14.758
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:09:14.758
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:09:14.758
CQG WebAPI | Disconnected. | 2019-05-28 21:09:14.763
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:09:14.763
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:11:14.771
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:11:14.771
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:11:14.777
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:11:14.777
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:11:15.788 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:11:15.788
CQG WebAPI | WebSocket closed. | 2019-05-28 21:11:15.788
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:11:15.788
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:11:15.788
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:11:15.789
CQG WebAPI | Disconnected. | 2019-05-28 21:11:15.805
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:11:15.805
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:13:15.811
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:13:15.811
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:13:15.906
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:13:15.906
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:13:16.941 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:13:16.942
CQG WebAPI | WebSocket closed. | 2019-05-28 21:13:16.942
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:13:16.942
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:13:16.942
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:13:16.942
CQG WebAPI | Disconnected. | 2019-05-28 21:13:16.950
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:13:16.950
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:15:16.964
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:15:16.964
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:15:16.976
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:15:16.976
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:15:18.017 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:15:18.015
CQG WebAPI | WebSocket closed. | 2019-05-28 21:15:18.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:15:18.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:15:18.015
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:15:18.017
CQG WebAPI | Disconnected. | 2019-05-28 21:15:18.023
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:15:18.023
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:17:18.045
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:17:18.045
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:17:18.045
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:17:18.045
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:17:19.078 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:17:19.079
CQG WebAPI | WebSocket closed. | 2019-05-28 21:17:19.079
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:17:19.079
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:17:19.079
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:17:19.078
CQG WebAPI | Disconnected. | 2019-05-28 21:17:19.094
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:17:19.094
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:19:19.116
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:19:19.116
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:19:19.289
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:19:19.289
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:19:20.330 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:19:20.341
CQG WebAPI | WebSocket closed. | 2019-05-28 21:19:20.341
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:19:20.341
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:19:20.341
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:19:20.330
CQG WebAPI | Disconnected. | 2019-05-28 21:19:20.349
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:19:20.349
Requested login tokens. | 2019-05-28 21:20:30.732
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:20:30.721
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Connecting to IP: 46.4.97.203. | 2019-05-28 21:20:30.721
Received 8 login tokens. | 2019-05-28 21:20:30.967
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. | 2019-05-28 21:20:31.215
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2019-05-28 21:20:31.241
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (1) | Closed. | 2019-05-28 21:20:31.241
CQG WebAPI | Connecting to server api.cqg.com | 2019-05-28 21:21:20.350
CQG WebSocket | Connecting to WebSocket server. | 2019-05-28 21:21:20.350
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-05-28 21:21:20.351
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2019-05-28 21:21:20.351
CQG WebSocket socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-05-28 21:21:21.391 *
CQG WebSocket | WebSocket closed. | 2019-05-28 21:21:21.391
CQG WebAPI | WebSocket closed. | 2019-05-28 21:21:21.391
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-28 21:21:21.391
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:21:21.391
CQG WebSocket socket (1) | Closed. | 2019-05-28 21:21:21.391
CQG WebAPI | Disconnected. | 2019-05-28 21:21:21.399
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-28 21:21:21.399
