Date/Time: Fri, 31 Jan 2025 17:47:14 +0000
Chart region jammed up ( can't see data )
View Count: 611
[2019-05-28 19:07:07]
User359096 - Posts: 2
I have a chart with 4 regions. Top region is where candles are located. I selected something while using the chart that shrunk the one region and now can not see the candles in the region. The other regions are fine. I thought to close the chartbook and reopen but when I went to do that I accidentally selected "save" so when I opened the charts the "problem" was saved also. I am familiar with the "black line" in the margin where price is located to expand the region but everything is so small I'm not able to find/see the black line. How can I expand the region back to a size where I can see the candles?
[2019-05-28 21:41:28]
Go through the Study Settings for each of the studies in Analysis >> Studies and check which one is displayed in Chart Region 1. One of those is going to be causing a problem.
