Date/Time: Fri, 07 Feb 2025 06:45:04 +0000
Toolbar icons different in ver 1925
View Count: 1874
[2019-05-28 15:26:00]
bigFish56 - Posts: 7
Hi Guys,
I have just upgraded to ver 1925 and my toolbar config has changed. Buttons that used to contain icons now contain text. How do I keep the same icons without reverting to an old version.
regards
James
imageToolbar_ver1919.png / V - Attached On 2019-05-28 15:25:04 UTC - Size: 17.76 KB - 467 views
imageToolbar_ver1925.png / V - Attached On 2019-05-28 15:25:18 UTC - Size: 17.15 KB - 453 views
[2019-05-28 20:41:44]
This is explained in detail here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1926
The images are still provided. You can change to the images through the Control Bar Button Properties.
[2020-05-25 13:16:44]
User164231 - Posts: 278
Why is the latest update missing in tool icon instead they are all in text? How to change it back?
[2020-05-25 15:36:13]
Ackin - Posts: 1865
User164231)
Refer to the notes here for version 2065:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065
Control Bar: Control Bar Button Properties
