Date/Time: Fri, 31 Jan 2025 18:07:15 +0000
Setting up multiple brokers on the same download
View Count: 771
[2019-05-28 14:58:17] |
User525965 - Posts: 153 |
Hi, i read that you can set up more than 1 broker on here at the same time. However when i go to data/trade service settings and enter in the 2nd account it kicks me off the first one. I dont see any instructions on how to set this up without downloading the software a 2nd time. I would like to run both accounts off the same 1 download of the software. |
[2019-05-28 23:21:52] |
You do need to use two instances of Sierra Chart: Using Multiple Data and Trading Services at the Same Time You can you work with different clearing firms and trading accounts, using this new service on the same connection: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
