Date/Time: Fri, 31 Jan 2025 20:43:05 +0000
connect to fxcm
View Count: 1213
[2019-05-28 12:08:41] |
User384999 - Posts: 28 |
hi i have sierra charts , I want to use the fxcm demo data feed, When i select this it does not give me the option to input my user / password
[2019-06-02 04:02:08] |
You need to use this data feed which is from FXCM, this is all that is supported: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
