Date/Time: Wed, 05 Feb 2025 03:46:37 +0000
how to calculate NET profit after deducting commission in each trade
View Count: 1037
[2019-05-28 09:10:02] |
User512854 - Posts: 24 |
how to do that when backtesting?
[2019-05-28 09:33:30] |
This question is not clear enough. Where is it in Sierra Chart that you are looking at the profit/loss of a Trade?
[2019-05-28 09:38:07] |
i am doing backtest, say 100share fired each time, i want to put 1$ commission on each firing (set of 100share) how to include in order to get net profit
[2019-05-29 04:30:54] |
You first need to specify the commission amount properly in the Global Symbol Settings for the symbol pattern. And then you can enable the use of the Commission setting for the Trades list. This is all documented here: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-26 11:28:49] |
User870514 - Posts: 25 |
Is it possible to specify the fees in more detail? For example for a trade based on the Maker / Taker model, the fee for Limit orders is different from Market orders. In the Global Symbol settings it is not possible to break fees down in such detail. A round turn could be any combination of Maker (limit, stop limit) or Taker (market, stop market) orders, the stats on this being available, it should be possible to calculate the PnL more accurately. Percentage terms entry is required. Date Time Of Last Edit: 2020-02-26 13:19:33
