Date/Time: Fri, 31 Jan 2025 17:51:26 +0000
How to have Sierra start in 64-bit mode?
View Count: 574
[2019-05-28 08:13:10] |
User360283 - Posts: 508 |
How to have Sierra start in 64-bit mode? Thanks |
[2019-05-28 09:42:21] |
Refer to: Software Download: Difference Between 32 and 64-bit Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
