Date/Time: Wed, 05 Mar 2025 22:44:17 +0000
XLM/STR Trendlines jumping and displaced immeditely when drawn.
View Count: 1050
[2019-05-27 15:37:26]
User35475 - Posts: 12
The trendline jumping problem is NOT the one described below since the objects can not initially drawn to chosen locations.
" There are reasons why a Chart Drawing that you have drawn with a Drawing Tool may move after (!!!) you have drawn it. The drawing could move during chart updating, after a download or re-download of historical chart data, when you change the period/timeframe of the chart bars, or when changing the scale of the chart.
Trendlines or many other drawing objects can not be drawn to places chosen but jump immediately near previously drawn trendlines or other drawing objects. For example Fibonacci projection 0 % level can not be drawn to place chosen but instead starts from different nearby location.
This all as if the drawing objects would be automatically placed to special locations as if with linear regression.
There is also drawing objects clustering syndrome. Fibonacci fan starting point, horizontal trendline and Fibonacci projection starting points jump to same vertical level of chart when drawn after each other.
z
This all happens also with fresh installation of Sierra Chart pre release version.
[2019-07-08 09:54:36]
To solve this problem you need to uncheck this option:
Chart Settings: Adjust Tool Values to Tick Size (Chart >> Chart Settings >> Chart Drawing menu)
