Date/Time: Fri, 31 Jan 2025 18:42:49 +0000
Bitmex order book issues
View Count: 719
[2019-05-27 12:27:11] |
User619308 - Posts: 7 |
Once again there is orderbook issues, which is more than disapointing, every time when there was bigger move orderbook gets broken so I can't use my custom trading study, so in fact I have losses from that reason. I understand that Bitmex has crappy api, and troubles with stability, but when I pay for software I reckon that I have right to expect that I will able to use them and make profit. SierraChart is great per se, but Bitmex connector is sometimes realy shitty. Can you solve problem with orderbook while a big moves? Same issue as here: BItmex ticker and orderbook issues |
[2019-05-27 13:34:21] |
The problem is on the BitMex side. That is definitive. We will reset the connection to BitMex.
[2019-05-27 13:37:01] |
This comment is 100% about BitMex only: but Bitmex connector is sometimes realy shitty.
