Date/Time: Fri, 31 Jan 2025 18:46:56 +0000
[Programming Help] - Subgraphs with non-continuous lines for non-zero values
View Count: 871
[2019-05-27 05:01:25] |
User553714 - Posts: 184 |
Is there any way to have a subgraph draw non-zero values, then break and be blank when values are zero and then start a new line when values are non zero again instead of it joining all non zero values as described in your documentation here; ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawZeros I would like the subgraph line to be non continuous; if you set DrawZeroes == 1 then there is that vertical line from the last non zero down to zero then back up again to the next non-zero value which I would like to avoid. Hopefully this is clear, let me know if you require a pic. |
[2019-05-27 15:35:32] |
You need to use this Draw Style: DRAWSTYLE_LINE_SKIP_ZEROS Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
