Date/Time: Fri, 31 Jan 2025 19:09:08 +0000
DOM depth levels not showing evenly
View Count: 701
[2019-05-26 13:24:11] |
coin boss - Posts: 19 |
For my DOM, in Chart settings Advanced settings 3, when I change maximum market depth levels from 0 to any other number, lets say 20. It shows the depth unevenly. It shows 20 on the bid, and only 8 on the offer. Any idea why? NOte: this is using bitmex, i also notice when i centre the dom, it jumps 50$ lower so current price is off the screen for some reason.. definitely something fishy, but perhaps its just bitmex. Date Time Of Last Edit: 2019-05-26 15:57:30
Screenshot_19.png / V - Attached On 2019-05-26 13:23:11 UTC - Size: 158.16 KB - 294 views |
[2019-05-26 17:12:10] |
We reset the market data connection to BitMex. See if that resolves the issues for you.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-26 17:12:18
[2019-05-26 17:26:41] |
yes, that fixed it.
