Date/Time: Sun, 24 Nov 2024 17:29:55 +0000
Connection problem
View Count: 1399
[2013-11-26 18:25:08] |
RQ - Posts: 50 |
Guys I would appreciate it if you would take a quick look at the log below. I was disconnected and then reconnected but I am wondering what exactly is going on. Should I be concerned? Socket closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2013-11-26 17:34:00 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:00 Connection to the external service has been lost. | 2013-11-26 17:34:00 Disconnected from FXCM FIX. | 2013-11-26 17:34:01 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:01 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:06 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:06 The network socket is connected. | 2013-11-26 17:34:06 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:06 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:06 Socket closed. No error. | 2013-11-26 17:34:06 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:06 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:06 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:06 Disconnected from FXCM FIX. | 2013-11-26 17:34:06 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:06 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:11 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:11 The network socket is connected. | 2013-11-26 17:34:11 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:12 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:12 Socket closed. No error. | 2013-11-26 17:34:12 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:12 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:12 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:12 Disconnected from FXCM FIX. | 2013-11-26 17:34:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:12 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:17 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:17 The network socket is connected. | 2013-11-26 17:34:17 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:17 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:17 Socket closed. No error. | 2013-11-26 17:34:17 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:17 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:17 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:17 Disconnected from FXCM FIX. | 2013-11-26 17:34:17 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:17 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:22 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:22 The network socket is connected. | 2013-11-26 17:34:23 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:23 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:23 Socket closed. No error. | 2013-11-26 17:34:23 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:23 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:23 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:23 Disconnected from FXCM FIX. | 2013-11-26 17:34:23 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:23 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:28 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:28 The network socket is connected. | 2013-11-26 17:34:28 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:29 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:29 Socket closed. No error. | 2013-11-26 17:34:29 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:29 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:29 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:29 Disconnected from FXCM FIX. | 2013-11-26 17:34:29 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:29 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:34 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:34 The network socket is connected. | 2013-11-26 17:34:34 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:34 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:34 Socket closed. No error. | 2013-11-26 17:34:34 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:34 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:34 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:34 Disconnected from FXCM FIX. | 2013-11-26 17:34:34 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:34 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:39 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:39 The network socket is connected. | 2013-11-26 17:34:39 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:40 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:40 Socket closed. No error. | 2013-11-26 17:34:40 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:40 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:40 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:40 Disconnected from FXCM FIX. | 2013-11-26 17:34:40 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:40 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:45 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:45 The network socket is connected. | 2013-11-26 17:34:45 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:45 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:45 Socket closed. No error. | 2013-11-26 17:34:45 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:45 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:45 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:45 Disconnected from FXCM FIX. | 2013-11-26 17:34:45 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:45 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:50 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:50 The network socket is connected. | 2013-11-26 17:34:51 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:51 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:51 Socket closed. No error. | 2013-11-26 17:34:51 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:51 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:51 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:51 Disconnected from FXCM FIX. | 2013-11-26 17:34:51 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:51 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:34:56 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:34:56 The network socket is connected. | 2013-11-26 17:34:56 FXCM FIX: Sending the Logon message. | 2013-11-26 17:34:57 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:34:57 Socket closed. No error. | 2013-11-26 17:34:57 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:34:57 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:34:57 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:34:57 Disconnected from FXCM FIX. | 2013-11-26 17:34:57 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:34:57 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:35:02 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:35:02 The network socket is connected. | 2013-11-26 17:35:02 FXCM FIX: Sending the Logon message. | 2013-11-26 17:35:02 FXCM FIX: Received a Reject <3> message. RefSeqNum = 1. RefMsgType = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed.. | 2013-11-26 17:35:02 Socket closed. No error. | 2013-11-26 17:35:02 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2013-11-26 17:35:02 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-26 17:35:02 To prevent further connection attempts, select File >> Disconnect. | 2013-11-26 17:35:02 Disconnected from FXCM FIX. | 2013-11-26 17:35:02 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-26 17:35:02 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8039 | 2013-11-26 17:35:07 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2013-11-26 17:35:07 The network socket is connected. | 2013-11-26 17:35:07 FXCM FIX: Sending the Logon message. | 2013-11-26 17:35:08 Connection with FXCM FIX server established. Sending logon user request... | 2013-11-26 17:35:08 FXCM FIX - User status: 0 U10R5_EC173D39545261A4E043A1283C0ADFD2_11262013173507587452_75IP;20;106153; | 2013-11-26 17:35:08 FXCM FIX: Requesting trading session status. | 2013-11-26 17:35:08 FXCM FIX: Connected. | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: GBPUSD | 2013-11-26 17:35:08 HD Request # 30 - Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2013-11-26 17:35:08 HD Request # 30 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:08 HD Request # 30 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: NZDCAD | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: NZDCHF | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: NZDJPY | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: NZDUSD | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: USDCHF | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: USDCAD | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: USDJPY | 2013-11-26 17:35:08 FXCM FIX Trading - Starting real-time market data updates for: AUDCAD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: AUDCHF | 2013-11-26 17:35:09 Trading session mode: Production. | 2013-11-26 17:35:09 Trading session status: Open. | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: AUDJPY | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: AUDNZD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: AUDUSD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: CADCHF | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: CADJPY | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: CHFJPY | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURAUD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURGBP | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURCAD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURJPY | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURCHF | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURUSD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: GBPAUD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: GBPCAD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: GBPCHF | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: GBPJPY | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: GBPNZD | 2013-11-26 17:35:09 FXCM FIX Trading - Starting real-time market data updates for: EURNZD | 2013-11-26 17:35:09 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:09 The network socket is connected. | 2013-11-26 17:35:10 HD Request # 30 - Sending historical data logon request message. | 2013-11-26 17:35:10 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:10 HD Request # 30 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:10 HD Request # 30 - Decompressing data. | 2013-11-26 17:35:10 HD Request # 30 - Receiving Intraday data for GBPUSD starting at 2013-11-26 17:34:03 | 2013-11-26 17:35:10 HD Request # 30 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:03 | 2013-11-26 17:35:10 The network socket for historical data has been closed. | 2013-11-26 17:35:10 HD Request # 30 - Received 25 records from 2013-11-26 17:34:03 to 2013-11-26 17:35:08 (65.0 seconds) and wrote 25 records for GBPUSD | 2013-11-26 17:35:10 HD Request # 30 - Intraday download COMPLETE for GBPUSD | 2013-11-26 17:35:10 Real-time Intraday chart data file updates started for GBPUSD | 2013-11-26 17:35:10 Added 2 Time and Sales records to Intraday data file for GBPUSD after download. | 2013-11-26 17:35:10 HD Request # 31 - Downloading Intraday chart data for NZDCAD to the file NZDCAD.scid. Service: fxcm | 2013-11-26 17:35:10 HD Request # 31 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:10 HD Request # 31 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:10 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:10 The network socket is connected. | 2013-11-26 17:35:10 HD Request # 31 - Sending historical data logon request message. | 2013-11-26 17:35:10 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:11 HD Request # 31 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:11 HD Request # 31 - Decompressing data. | 2013-11-26 17:35:11 HD Request # 31 - Receiving Intraday data for NZDCAD starting at 2013-11-26 17:34:12 | 2013-11-26 17:35:11 HD Request # 31 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:12 | 2013-11-26 17:35:11 The network socket for historical data has been closed. | 2013-11-26 17:35:11 HD Request # 31 - Received 16 records from 2013-11-26 17:34:12 to 2013-11-26 17:35:08 (56.0 seconds) and wrote 16 records for NZDCAD | 2013-11-26 17:35:11 HD Request # 31 - Intraday download COMPLETE for NZDCAD | 2013-11-26 17:35:11 Real-time Intraday chart data file updates started for NZDCAD | 2013-11-26 17:35:11 Added 1 Time and Sales records to Intraday data file for NZDCAD after download. | 2013-11-26 17:35:11 HD Request # 32 - Downloading Intraday chart data for NZDCHF to the file NZDCHF.scid. Service: fxcm | 2013-11-26 17:35:11 HD Request # 32 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:11 HD Request # 32 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:11 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:11 The network socket is connected. | 2013-11-26 17:35:12 HD Request # 32 - Sending historical data logon request message. | 2013-11-26 17:35:12 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:12 HD Request # 32 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:12 HD Request # 32 - Decompressing data. | 2013-11-26 17:35:12 HD Request # 32 - Receiving Intraday data for NZDCHF starting at 2013-11-26 17:34:08 | 2013-11-26 17:35:12 HD Request # 32 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:08 | 2013-11-26 17:35:12 The network socket for historical data has been closed. | 2013-11-26 17:35:12 HD Request # 32 - Received 24 records from 2013-11-26 17:34:08 to 2013-11-26 17:35:08 (60.0 seconds) and wrote 24 records for NZDCHF | 2013-11-26 17:35:12 HD Request # 32 - Intraday download COMPLETE for NZDCHF | 2013-11-26 17:35:12 Real-time Intraday chart data file updates started for NZDCHF | 2013-11-26 17:35:12 Added 1 Time and Sales records to Intraday data file for NZDCHF after download. | 2013-11-26 17:35:12 HD Request # 33 - Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: fxcm | 2013-11-26 17:35:12 HD Request # 33 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:12 HD Request # 33 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:12 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:12 The network socket is connected. | 2013-11-26 17:35:12 HD Request # 33 - Sending historical data logon request message. | 2013-11-26 17:35:12 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:12 HD Request # 33 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:12 HD Request # 33 - Decompressing data. | 2013-11-26 17:35:13 HD Request # 33 - Receiving Intraday data for NZDJPY starting at 2013-11-26 17:34:02 | 2013-11-26 17:35:13 HD Request # 33 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:02 | 2013-11-26 17:35:13 The network socket for historical data has been closed. | 2013-11-26 17:35:13 HD Request # 33 - Received 17 records from 2013-11-26 17:34:02 to 2013-11-26 17:35:07 (65.0 seconds) and wrote 17 records for NZDJPY | 2013-11-26 17:35:13 HD Request # 33 - Intraday download COMPLETE for NZDJPY | 2013-11-26 17:35:13 Real-time Intraday chart data file updates started for NZDJPY | 2013-11-26 17:35:13 Added 1 Time and Sales records to Intraday data file for NZDJPY after download. | 2013-11-26 17:35:13 HD Request # 34 - Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2013-11-26 17:35:13 HD Request # 34 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:13 HD Request # 34 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:13 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:13 The network socket is connected. | 2013-11-26 17:35:13 HD Request # 34 - Sending historical data logon request message. | 2013-11-26 17:35:13 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:13 HD Request # 34 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:13 HD Request # 34 - Decompressing data. | 2013-11-26 17:35:13 HD Request # 34 - Receiving Intraday data for NZDUSD starting at 2013-11-26 17:34:12 | 2013-11-26 17:35:13 HD Request # 34 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:12 | 2013-11-26 17:35:13 The network socket for historical data has been closed. | 2013-11-26 17:35:13 HD Request # 34 - Received 22 records from 2013-11-26 17:34:12 to 2013-11-26 17:35:08 (56.0 seconds) and wrote 22 records for NZDUSD | 2013-11-26 17:35:13 HD Request # 34 - Intraday download COMPLETE for NZDUSD | 2013-11-26 17:35:13 Real-time Intraday chart data file updates started for NZDUSD | 2013-11-26 17:35:13 Added 1 Time and Sales records to Intraday data file for NZDUSD after download. | 2013-11-26 17:35:13 HD Request # 35 - Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2013-11-26 17:35:13 HD Request # 35 - Last Date-Time in file: 2013-11-26 17:33:55.0 | 2013-11-26 17:35:13 HD Request # 35 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:13 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:13 The network socket is connected. | 2013-11-26 17:35:14 HD Request # 35 - Sending historical data logon request message. | 2013-11-26 17:35:14 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:14 HD Request # 35 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:14 HD Request # 35 - Decompressing data. | 2013-11-26 17:35:14 HD Request # 35 - Receiving Intraday data for USDCHF starting at 2013-11-26 17:34:08 | 2013-11-26 17:35:14 HD Request # 35 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:08 | 2013-11-26 17:35:14 The network socket for historical data has been closed. | 2013-11-26 17:35:14 HD Request # 35 - Received 31 records from 2013-11-26 17:34:08 to 2013-11-26 17:35:12 (64.0 seconds) and wrote 31 records for USDCHF | 2013-11-26 17:35:14 HD Request # 35 - Intraday download COMPLETE for USDCHF | 2013-11-26 17:35:14 Real-time Intraday chart data file updates started for USDCHF | 2013-11-26 17:35:14 Added 1 Time and Sales records to Intraday data file for USDCHF after download. | 2013-11-26 17:35:14 HD Request # 36 - Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2013-11-26 17:35:14 HD Request # 36 - Last Date-Time in file: 2013-11-26 17:33:58.0 | 2013-11-26 17:35:14 HD Request # 36 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:14 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:14 The network socket is connected. | 2013-11-26 17:35:14 HD Request # 36 - Sending historical data logon request message. | 2013-11-26 17:35:14 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:14 HD Request # 36 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:14 HD Request # 36 - Decompressing data. | 2013-11-26 17:35:14 HD Request # 36 - Receiving Intraday data for USDCAD starting at 2013-11-26 17:34:00 | 2013-11-26 17:35:14 HD Request # 36 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:00 | 2013-11-26 17:35:14 The network socket for historical data has been closed. | 2013-11-26 17:35:14 HD Request # 36 - Received 9 records from 2013-11-26 17:34:00 to 2013-11-26 17:34:49 (49.0 seconds) and wrote 9 records for USDCAD | 2013-11-26 17:35:14 HD Request # 36 - Intraday download COMPLETE for USDCAD | 2013-11-26 17:35:15 Real-time Intraday chart data file updates started for USDCAD | 2013-11-26 17:35:15 Added 1 Time and Sales records to Intraday data file for USDCAD after download. | 2013-11-26 17:35:15 HD Request # 37 - Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2013-11-26 17:35:15 HD Request # 37 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:15 HD Request # 37 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:15 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:15 The network socket is connected. | 2013-11-26 17:35:15 HD Request # 37 - Sending historical data logon request message. | 2013-11-26 17:35:15 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:15 HD Request # 37 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:15 HD Request # 37 - Decompressing data. | 2013-11-26 17:35:15 HD Request # 37 - Receiving Intraday data for USDJPY starting at 2013-11-26 17:33:56 | 2013-11-26 17:35:15 HD Request # 37 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:56 | 2013-11-26 17:35:15 The network socket for historical data has been closed. | 2013-11-26 17:35:15 HD Request # 37 - Received 11 records from 2013-11-26 17:33:56 to 2013-11-26 17:35:11 (75.0 seconds) and wrote 11 records for USDJPY | 2013-11-26 17:35:15 HD Request # 37 - Intraday download COMPLETE for USDJPY | 2013-11-26 17:35:15 Real-time Intraday chart data file updates started for USDJPY | 2013-11-26 17:35:15 HD Request # 38 - Downloading Intraday chart data for AUDCAD to the file AUDCAD.scid. Service: fxcm | 2013-11-26 17:35:15 HD Request # 38 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:15 HD Request # 38 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:15 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:15 The network socket is connected. | 2013-11-26 17:35:15 HD Request # 38 - Sending historical data logon request message. | 2013-11-26 17:35:15 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:16 HD Request # 38 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:16 HD Request # 38 - Decompressing data. | 2013-11-26 17:35:16 HD Request # 38 - Receiving Intraday data for AUDCAD starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:16 HD Request # 38 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:16 The network socket for historical data has been closed. | 2013-11-26 17:35:16 HD Request # 38 - Received 35 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:13 (74.0 seconds) and wrote 35 records for AUDCAD | 2013-11-26 17:35:16 HD Request # 38 - Intraday download COMPLETE for AUDCAD | 2013-11-26 17:35:16 Real-time Intraday chart data file updates started for AUDCAD | 2013-11-26 17:35:16 HD Request # 39 - Downloading Intraday chart data for AUDCHF to the file AUDCHF.scid. Service: fxcm | 2013-11-26 17:35:16 HD Request # 39 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:16 HD Request # 39 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:16 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:16 The network socket is connected. | 2013-11-26 17:35:16 HD Request # 39 - Sending historical data logon request message. | 2013-11-26 17:35:16 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:16 HD Request # 39 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:16 HD Request # 39 - Decompressing data. | 2013-11-26 17:35:16 HD Request # 39 - Receiving Intraday data for AUDCHF starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:16 HD Request # 39 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:16 The network socket for historical data has been closed. | 2013-11-26 17:35:16 HD Request # 39 - Received 39 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:13 (74.0 seconds) and wrote 39 records for AUDCHF | 2013-11-26 17:35:16 HD Request # 39 - Intraday download COMPLETE for AUDCHF | 2013-11-26 17:35:16 Real-time Intraday chart data file updates started for AUDCHF | 2013-11-26 17:35:16 HD Request # 40 - Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2013-11-26 17:35:16 HD Request # 40 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:16 HD Request # 40 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:16 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:16 The network socket is connected. | 2013-11-26 17:35:17 HD Request # 40 - Sending historical data logon request message. | 2013-11-26 17:35:17 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:17 HD Request # 40 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:17 HD Request # 40 - Decompressing data. | 2013-11-26 17:35:17 HD Request # 40 - Receiving Intraday data for AUDJPY starting at 2013-11-26 17:33:56 | 2013-11-26 17:35:17 HD Request # 40 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:56 | 2013-11-26 17:35:17 The network socket for historical data has been closed. | 2013-11-26 17:35:17 HD Request # 40 - Received 32 records from 2013-11-26 17:33:56 to 2013-11-26 17:35:13 (77.0 seconds) and wrote 32 records for AUDJPY | 2013-11-26 17:35:17 HD Request # 40 - Intraday download COMPLETE for AUDJPY | 2013-11-26 17:35:17 Real-time Intraday chart data file updates started for AUDJPY | 2013-11-26 17:35:17 HD Request # 41 - Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2013-11-26 17:35:17 HD Request # 41 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:17 HD Request # 41 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:17 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:17 The network socket is connected. | 2013-11-26 17:35:17 HD Request # 41 - Sending historical data logon request message. | 2013-11-26 17:35:17 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:17 HD Request # 41 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:17 HD Request # 41 - Decompressing data. | 2013-11-26 17:35:18 HD Request # 41 - Receiving Intraday data for AUDNZD starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:18 HD Request # 41 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:18 The network socket for historical data has been closed. | 2013-11-26 17:35:18 HD Request # 41 - Received 30 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:13 (74.0 seconds) and wrote 30 records for AUDNZD | 2013-11-26 17:35:18 HD Request # 41 - Intraday download COMPLETE for AUDNZD | 2013-11-26 17:35:18 Real-time Intraday chart data file updates started for AUDNZD | 2013-11-26 17:35:18 HD Request # 42 - Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2013-11-26 17:35:18 HD Request # 42 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:18 HD Request # 42 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:18 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:18 The network socket is connected. | 2013-11-26 17:35:18 HD Request # 42 - Sending historical data logon request message. | 2013-11-26 17:35:18 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:18 HD Request # 42 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:18 HD Request # 42 - Decompressing data. | 2013-11-26 17:35:18 HD Request # 42 - Receiving Intraday data for AUDUSD starting at 2013-11-26 17:34:01 | 2013-11-26 17:35:18 HD Request # 42 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:01 | 2013-11-26 17:35:18 The network socket for historical data has been closed. | 2013-11-26 17:35:18 HD Request # 42 - Received 42 records from 2013-11-26 17:34:01 to 2013-11-26 17:35:18 (77.0 seconds) and wrote 42 records for AUDUSD | 2013-11-26 17:35:18 HD Request # 42 - Intraday download COMPLETE for AUDUSD | 2013-11-26 17:35:18 Real-time Intraday chart data file updates started for AUDUSD | 2013-11-26 17:35:18 HD Request # 43 - Downloading Intraday chart data for CADCHF to the file CADCHF.scid. Service: fxcm | 2013-11-26 17:35:18 HD Request # 43 - Last Date-Time in file: 2013-11-26 17:33:58.0 | 2013-11-26 17:35:18 HD Request # 43 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:18 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:18 The network socket is connected. | 2013-11-26 17:35:19 HD Request # 43 - Sending historical data logon request message. | 2013-11-26 17:35:19 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:19 HD Request # 43 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:19 HD Request # 43 - Decompressing data. | 2013-11-26 17:35:19 HD Request # 43 - Receiving Intraday data for CADCHF starting at 2013-11-26 17:34:02 | 2013-11-26 17:35:19 HD Request # 43 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:02 | 2013-11-26 17:35:19 The network socket for historical data has been closed. | 2013-11-26 17:35:19 HD Request # 43 - Received 19 records from 2013-11-26 17:34:02 to 2013-11-26 17:35:04 (62.0 seconds) and wrote 19 records for CADCHF | 2013-11-26 17:35:19 HD Request # 43 - Intraday download COMPLETE for CADCHF | 2013-11-26 17:35:19 Real-time Intraday chart data file updates started for CADCHF | 2013-11-26 17:35:19 Added 1 Time and Sales records to Intraday data file for CADCHF after download. | 2013-11-26 17:35:19 HD Request # 44 - Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2013-11-26 17:35:19 HD Request # 44 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:19 HD Request # 44 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:19 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:19 The network socket is connected. | 2013-11-26 17:35:19 HD Request # 44 - Sending historical data logon request message. | 2013-11-26 17:35:19 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:20 HD Request # 44 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:20 HD Request # 44 - Decompressing data. | 2013-11-26 17:35:20 HD Request # 44 - Receiving Intraday data for CADJPY starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:20 HD Request # 44 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:20 The network socket for historical data has been closed. | 2013-11-26 17:35:20 HD Request # 44 - Received 17 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:10 (71.0 seconds) and wrote 17 records for CADJPY | 2013-11-26 17:35:20 HD Request # 44 - Intraday download COMPLETE for CADJPY | 2013-11-26 17:35:20 Real-time Intraday chart data file updates started for CADJPY | 2013-11-26 17:35:20 Added 1 Time and Sales records to Intraday data file for CADJPY after download. | 2013-11-26 17:35:20 HD Request # 45 - Downloading Intraday chart data for CHFJPY to the file CHFJPY.scid. Service: fxcm | 2013-11-26 17:35:20 HD Request # 45 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:20 HD Request # 45 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:20 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:20 The network socket is connected. | 2013-11-26 17:35:20 HD Request # 45 - Sending historical data logon request message. | 2013-11-26 17:35:20 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:20 HD Request # 45 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:20 HD Request # 45 - Decompressing data. | 2013-11-26 17:35:21 HD Request # 45 - Receiving Intraday data for CHFJPY starting at 2013-11-26 17:34:02 | 2013-11-26 17:35:21 HD Request # 45 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:02 | 2013-11-26 17:35:21 The network socket for historical data has been closed. | 2013-11-26 17:35:21 HD Request # 45 - Received 22 records from 2013-11-26 17:34:02 to 2013-11-26 17:35:12 (70.0 seconds) and wrote 22 records for CHFJPY | 2013-11-26 17:35:21 HD Request # 45 - Intraday download COMPLETE for CHFJPY | 2013-11-26 17:35:21 Real-time Intraday chart data file updates started for CHFJPY | 2013-11-26 17:35:21 HD Request # 46 - Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2013-11-26 17:35:21 HD Request # 46 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:21 HD Request # 46 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:21 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:21 The network socket is connected. | 2013-11-26 17:35:24 HD Request # 46 - Sending historical data logon request message. | 2013-11-26 17:35:24 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:24 HD Request # 46 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:24 HD Request # 46 - Decompressing data. | 2013-11-26 17:35:24 HD Request # 46 - Receiving Intraday data for EURAUD starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:24 HD Request # 46 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:24 The network socket for historical data has been closed. | 2013-11-26 17:35:24 HD Request # 46 - Received 36 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:22 (83.0 seconds) and wrote 36 records for EURAUD | 2013-11-26 17:35:24 HD Request # 46 - Intraday download COMPLETE for EURAUD | 2013-11-26 17:35:24 Real-time Intraday chart data file updates started for EURAUD | 2013-11-26 17:35:24 HD Request # 47 - Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2013-11-26 17:35:24 HD Request # 47 - Last Date-Time in file: 2013-11-26 17:33:58.0 | 2013-11-26 17:35:24 HD Request # 47 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:24 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:24 The network socket is connected. | 2013-11-26 17:35:24 HD Request # 47 - Sending historical data logon request message. | 2013-11-26 17:35:24 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:25 HD Request # 47 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:25 HD Request # 47 - Decompressing data. | 2013-11-26 17:35:25 HD Request # 47 - Receiving Intraday data for EURGBP starting at 2013-11-26 17:33:58 | 2013-11-26 17:35:25 HD Request # 47 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:58 | 2013-11-26 17:35:25 The network socket for historical data has been closed. | 2013-11-26 17:35:25 HD Request # 47 - Received 23 records from 2013-11-26 17:33:58 to 2013-11-26 17:35:23 (85.0 seconds) and wrote 23 records for EURGBP | 2013-11-26 17:35:25 HD Request # 47 - Intraday download COMPLETE for EURGBP | 2013-11-26 17:35:25 Real-time Intraday chart data file updates started for EURGBP | 2013-11-26 17:35:25 Added 1 Time and Sales records to Intraday data file for EURGBP after download. | 2013-11-26 17:35:25 HD Request # 48 - Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2013-11-26 17:35:25 HD Request # 48 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:25 HD Request # 48 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:25 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:25 The network socket is connected. | 2013-11-26 17:35:25 HD Request # 48 - Sending historical data logon request message. | 2013-11-26 17:35:25 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:25 HD Request # 48 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:25 HD Request # 48 - Decompressing data. | 2013-11-26 17:35:25 HD Request # 48 - Receiving Intraday data for EURCAD starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:25 HD Request # 48 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:25 The network socket for historical data has been closed. | 2013-11-26 17:35:25 HD Request # 48 - Received 34 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:23 (84.0 seconds) and wrote 34 records for EURCAD | 2013-11-26 17:35:25 HD Request # 48 - Intraday download COMPLETE for EURCAD | 2013-11-26 17:35:25 Real-time Intraday chart data file updates started for EURCAD | 2013-11-26 17:35:25 HD Request # 49 - Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2013-11-26 17:35:25 HD Request # 49 - Last Date-Time in file: 2013-11-26 17:33:56.0 | 2013-11-26 17:35:25 HD Request # 49 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:25 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:25 The network socket is connected. | 2013-11-26 17:35:25 HD Request # 49 - Sending historical data logon request message. | 2013-11-26 17:35:25 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:26 HD Request # 49 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:26 HD Request # 49 - Decompressing data. | 2013-11-26 17:35:26 HD Request # 49 - Receiving Intraday data for EURJPY starting at 2013-11-26 17:34:02 | 2013-11-26 17:35:26 HD Request # 49 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:02 | 2013-11-26 17:35:26 The network socket for historical data has been closed. | 2013-11-26 17:35:26 HD Request # 49 - Received 32 records from 2013-11-26 17:34:02 to 2013-11-26 17:35:22 (80.0 seconds) and wrote 32 records for EURJPY | 2013-11-26 17:35:26 HD Request # 49 - Intraday download COMPLETE for EURJPY | 2013-11-26 17:35:26 Real-time Intraday chart data file updates started for EURJPY | 2013-11-26 17:35:26 Added 1 Time and Sales records to Intraday data file for EURJPY after download. | 2013-11-26 17:35:26 HD Request # 50 - Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2013-11-26 17:35:26 HD Request # 50 - Last Date-Time in file: 2013-11-26 17:33:52.0 | 2013-11-26 17:35:26 HD Request # 50 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:26 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:26 The network socket is connected. | 2013-11-26 17:35:26 HD Request # 50 - Sending historical data logon request message. | 2013-11-26 17:35:26 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:26 HD Request # 50 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:26 HD Request # 50 - Decompressing data. | 2013-11-26 17:35:26 HD Request # 50 - Receiving Intraday data for EURCHF starting at 2013-11-26 17:34:12 | 2013-11-26 17:35:26 HD Request # 50 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:12 | 2013-11-26 17:35:26 The network socket for historical data has been closed. | 2013-11-26 17:35:26 HD Request # 50 - Received 14 records from 2013-11-26 17:34:12 to 2013-11-26 17:35:23 (71.0 seconds) and wrote 14 records for EURCHF | 2013-11-26 17:35:26 HD Request # 50 - Intraday download COMPLETE for EURCHF | 2013-11-26 17:35:26 Real-time Intraday chart data file updates started for EURCHF | 2013-11-26 17:35:26 HD Request # 51 - Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2013-11-26 17:35:26 HD Request # 51 - Last Date-Time in file: 2013-11-26 17:33:57.0 | 2013-11-26 17:35:26 HD Request # 51 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:26 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:26 The network socket is connected. | 2013-11-26 17:35:26 HD Request # 51 - Sending historical data logon request message. | 2013-11-26 17:35:26 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:26 HD Request # 51 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:26 HD Request # 51 - Decompressing data. | 2013-11-26 17:35:26 HD Request # 51 - Receiving Intraday data for EURUSD starting at 2013-11-26 17:34:05 | 2013-11-26 17:35:26 HD Request # 51 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:05 | 2013-11-26 17:35:26 The network socket for historical data has been closed. | 2013-11-26 17:35:26 HD Request # 51 - Received 26 records from 2013-11-26 17:34:05 to 2013-11-26 17:35:22 (77.0 seconds) and wrote 26 records for EURUSD | 2013-11-26 17:35:26 HD Request # 51 - Intraday download COMPLETE for EURUSD | 2013-11-26 17:35:26 Real-time Intraday chart data file updates started for EURUSD | 2013-11-26 17:35:26 Added 2 Time and Sales records to Intraday data file for EURUSD after download. | 2013-11-26 17:35:26 HD Request # 52 - Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2013-11-26 17:35:26 HD Request # 52 - Last Date-Time in file: 2013-11-26 17:33:59.0 | 2013-11-26 17:35:26 HD Request # 52 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:27 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:27 The network socket is connected. | 2013-11-26 17:35:27 HD Request # 52 - Sending historical data logon request message. | 2013-11-26 17:35:27 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:27 HD Request # 52 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:27 HD Request # 52 - Decompressing data. | 2013-11-26 17:35:27 HD Request # 52 - Receiving Intraday data for GBPAUD starting at 2013-11-26 17:33:59 | 2013-11-26 17:35:27 HD Request # 52 - Timestamp of first Intraday data file record written: 2013-11-26 17:33:59 | 2013-11-26 17:35:27 The network socket for historical data has been closed. | 2013-11-26 17:35:27 HD Request # 52 - Received 51 records from 2013-11-26 17:33:59 to 2013-11-26 17:35:24 (85.0 seconds) and wrote 51 records for GBPAUD | 2013-11-26 17:35:27 HD Request # 52 - Intraday download COMPLETE for GBPAUD | 2013-11-26 17:35:27 Real-time Intraday chart data file updates started for GBPAUD | 2013-11-26 17:35:27 Added 1 Time and Sales records to Intraday data file for GBPAUD after download. | 2013-11-26 17:35:27 HD Request # 53 - Downloading Intraday chart data for GBPCAD to the file GBPCAD.scid. Service: fxcm | 2013-11-26 17:35:27 HD Request # 53 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:27 HD Request # 53 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:27 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:27 The network socket is connected. | 2013-11-26 17:35:27 HD Request # 53 - Sending historical data logon request message. | 2013-11-26 17:35:27 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:28 HD Request # 53 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:28 HD Request # 53 - Decompressing data. | 2013-11-26 17:35:28 HD Request # 53 - Receiving Intraday data for GBPCAD starting at 2013-11-26 17:34:00 | 2013-11-26 17:35:28 HD Request # 53 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:00 | 2013-11-26 17:35:28 The network socket for historical data has been closed. | 2013-11-26 17:35:28 HD Request # 53 - Received 24 records from 2013-11-26 17:34:00 to 2013-11-26 17:35:09 (69.0 seconds) and wrote 24 records for GBPCAD | 2013-11-26 17:35:28 HD Request # 53 - Intraday download COMPLETE for GBPCAD | 2013-11-26 17:35:28 Real-time Intraday chart data file updates started for GBPCAD | 2013-11-26 17:35:28 Added 1 Time and Sales records to Intraday data file for GBPCAD after download. | 2013-11-26 17:35:28 HD Request # 54 - Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2013-11-26 17:35:28 HD Request # 54 - Last Date-Time in file: 2013-11-26 17:33:55.0 | 2013-11-26 17:35:28 HD Request # 54 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:28 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:28 The network socket is connected. | 2013-11-26 17:35:28 HD Request # 54 - Sending historical data logon request message. | 2013-11-26 17:35:28 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:28 HD Request # 54 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:28 HD Request # 54 - Decompressing data. | 2013-11-26 17:35:29 HD Request # 54 - Receiving Intraday data for GBPCHF starting at 2013-11-26 17:34:03 | 2013-11-26 17:35:29 HD Request # 54 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:03 | 2013-11-26 17:35:29 The network socket for historical data has been closed. | 2013-11-26 17:35:29 HD Request # 54 - Received 23 records from 2013-11-26 17:34:03 to 2013-11-26 17:35:27 (84.0 seconds) and wrote 23 records for GBPCHF | 2013-11-26 17:35:29 HD Request # 54 - Intraday download COMPLETE for GBPCHF | 2013-11-26 17:35:29 Real-time Intraday chart data file updates started for GBPCHF | 2013-11-26 17:35:29 Added 2 Time and Sales records to Intraday data file for GBPCHF after download. | 2013-11-26 17:35:29 HD Request # 55 - Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2013-11-26 17:35:29 HD Request # 55 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:29 HD Request # 55 - Using server: ds3.sierracharts.com port 10149 | 2013-11-26 17:35:29 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-11-26 17:35:29 The network socket is connected. | 2013-11-26 17:35:29 HD Request # 55 - Sending historical data logon request message. | 2013-11-26 17:35:29 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:29 HD Request # 55 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:29 HD Request # 55 - Decompressing data. | 2013-11-26 17:35:29 HD Request # 55 - Receiving Intraday data for GBPJPY starting at 2013-11-26 17:34:00 | 2013-11-26 17:35:29 HD Request # 55 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:00 | 2013-11-26 17:35:29 The network socket for historical data has been closed. | 2013-11-26 17:35:29 HD Request # 55 - Received 26 records from 2013-11-26 17:34:00 to 2013-11-26 17:35:28 (88.0 seconds) and wrote 26 records for GBPJPY | 2013-11-26 17:35:29 HD Request # 55 - Intraday download COMPLETE for GBPJPY | 2013-11-26 17:35:29 Real-time Intraday chart data file updates started for GBPJPY | 2013-11-26 17:35:29 Added 2 Time and Sales records to Intraday data file for GBPJPY after download. | 2013-11-26 17:35:29 HD Request # 56 - Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2013-11-26 17:35:29 HD Request # 56 - Last Date-Time in file: 2013-11-26 17:34:00.0 | 2013-11-26 17:35:29 HD Request # 56 - Using server: ds5.sierracharts.com port 10149 | 2013-11-26 17:35:29 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-11-26 17:35:29 The network socket is connected. | 2013-11-26 17:35:29 HD Request # 56 - Sending historical data logon request message. | 2013-11-26 17:35:29 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:30 HD Request # 56 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:30 HD Request # 56 - Decompressing data. | 2013-11-26 17:35:30 HD Request # 56 - Receiving Intraday data for GBPNZD starting at 2013-11-26 17:34:00 | 2013-11-26 17:35:30 HD Request # 56 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:00 | 2013-11-26 17:35:30 The network socket for historical data has been closed. | 2013-11-26 17:35:30 HD Request # 56 - Received 38 records from 2013-11-26 17:34:00 to 2013-11-26 17:35:29 (89.0 seconds) and wrote 38 records for GBPNZD | 2013-11-26 17:35:30 HD Request # 56 - Intraday download COMPLETE for GBPNZD | 2013-11-26 17:35:30 Real-time Intraday chart data file updates started for GBPNZD | 2013-11-26 17:35:30 HD Request # 57 - Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2013-11-26 17:35:30 HD Request # 57 - Last Date-Time in file: 2013-11-26 17:33:57.0 | 2013-11-26 17:35:30 HD Request # 57 - Using server: ds4.sierracharts.com port 10149 | 2013-11-26 17:35:30 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-11-26 17:35:30 The network socket is connected. | 2013-11-26 17:35:30 HD Request # 57 - Sending historical data logon request message. | 2013-11-26 17:35:30 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-26 17:35:30 HD Request # 57 - Requesting up to 93 days of Intraday data. Record interval: 1 | 2013-11-26 17:35:30 HD Request # 57 - Decompressing data. | 2013-11-26 17:35:31 HD Request # 57 - Receiving Intraday data for EURNZD starting at 2013-11-26 17:34:14 | 2013-11-26 17:35:31 HD Request # 57 - Timestamp of first Intraday data file record written: 2013-11-26 17:34:14 | 2013-11-26 17:35:31 The network socket for historical data has been closed. | 2013-11-26 17:35:31 HD Request # 57 - Received 35 records from 2013-11-26 17:34:14 to 2013-11-26 17:35:29 (75.0 seconds) and wrote 35 records for EURNZD | 2013-11-26 17:35:31 HD Request # 57 - Intraday download COMPLETE for EURNZD | 2013-11-26 17:35:31 Real-time Intraday chart data file updates started for EURNZD | 2013-11-26 17:35:31 Added 1 Time and Sales records to Intraday data file for EURNZD after download. | 2013-11-26 17:35:31 Date Time Of Last Edit: 2013-11-26 18:26:29
[2013-11-27 03:35:53] |
For what exactly is going on, we do not know. that is impossible for us to say since we do not control the network or the server. There is nothing that concerns us in this Message Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
