Date/Time: Fri, 31 Jan 2025 18:52:53 +0000
Customise Chart Drawing Menu - Colour options
View Count: 1732
[2019-05-26 02:44:54]
User629461 - Posts: 184
Does anyone know if there's a way to customise the available colour options on the Chart Drawing Menu when you right click on a drawing element? The default list of colour are not all the one's I use and would like to modify this list.
[2019-05-26 05:06:15]
User745789 - Posts: 356
Try this Chart Drawing Tools: Customizing Colors on the Menu
Personally, I wish I'd known this before allocating other custom colors to the bottom row. As time goes by, you also have to remember not to overwrite your bottom row custom colors.
[2019-05-26 05:18:56]
Thanks a bunch!
