Date/Time: Fri, 31 Jan 2025 19:07:19 +0000
[User Discussion] - BitMEX system overload
View Count: 1418
[2019-05-25 20:34:55]
User116783 - Posts: 84
Is there a way to auto-generate a new stop-loss order in the event that the 1st stop-loss is rejected due to system overload?
This happened to me last week. Using a simple bracket order, my trade got filled, but then the BitMEX system overloaded, and my attached order stop-loss and profit target were both rejected.
This occurred while I was asleep and caused me to get liquidated, which really, really sucked.
ZS
Date Time Of Last Edit: 2019-05-25 20:35:52
[2019-05-26 04:11:31]
I believe I've found a solution (assuming this works with the BitMEX): Attached Orders: Automatic Replacement Market Order for Rejected Stop Attached Order
When Global Settings >> General Trade Settings >> Auto-Send Market Order On Rejected Stop Attached Order is enabled and a Stop Attached Order is Rejected after being sent and originally had an Order Sent status, it will be resent as a Market order to offset the new position established by its parent order.
Date Time Of Last Edit: 2019-05-26 04:17:51
[2019-05-26 15:12:43]
I have a question for support.
With regards to market order replacement for a rejected stop, what trigger price will the replacement stop-loss be?
The same price as the original stop-loss that was rejected?
For example, a parent order is a buy at 8000, with a stop-loss at 7980 that gets rejected.
Will the replacement stop-loss also be 7980?
ZS
Date Time Of Last Edit: 2019-05-26 15:20:05
