Date/Time: Sat, 26 Apr 2025 09:40:34 +0000
Server side orders
View Count: 2342
[2019-05-25 17:03:17] |
caligola - Posts: 116 |
Could you please confirm that with CQG routing as soon as a pending order is filled then Sierra send a Server-side OCO orders from my PC? There are any differences if I use a MIT order as a Target in the OCO instead of a Limit Order? Does the same apply in the Eurex and in the CME? |
[2019-05-28 09:54:21] |
Yes if the option is enabled for that and this is explained in detail here: Attached Orders: General Management of Attached Orders And full server-side bracket orders are supported with this service: Sierra Chart / Trading Technologies Futures Order Routing Service There are any differences if I use a MIT order as a Target in the OCO instead of a Limit Order? Other than the order type, no.Does the same apply in the Eurex and in the CME? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-28 09:55:52
[2019-05-29 06:30:48] |
very good And full server-side bracket orders are supported with this service:
Sierra Chart / Trading Technologies Futures Order Routing Service Do you mean that also scale in/out are fully supported with TT routing and Sierra intermediary servers? There is something that is not supported with this setup? |
[2019-05-29 10:40:31] |
Yes of course . This does not depend upon any server-side functionality.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-29 10:40:39
[2019-08-02 16:03:16] |
AMP told me that MIT orders are not supported by CQG and by TT routing Are MIT orders supported as a Target in OCO by TT/Sierra routing (maybe using Sierra Chart Intermediary Servers)? How I could use MIT orders as Target (Eurex) if all the aboves are not supported? Using / Not using server-side orders could have any relevance? thanks Date Time Of Last Edit: 2019-08-03 09:09:16
[2019-08-03 09:55:10] |
There is a client MIT order you can use: Order Types: Market if Touched - Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-03 10:41:52] |
Thanks, in case of TT/Sierra routing the client MIT OCO target will be managed locally on my PC or on the Sierra Chart Intermediary Server? Could I still use server-side OCO orders with CQG routing to have a Stop loss server-side while MIT-Client target is locally managed on my PC? |
[2019-08-03 11:32:30] |
It will be managed locally on your Sierra Chart running on your desktop. Could I still use server-side OCO orders with CQG routing to have a Stop loss server-side while MIT-Client target is locally managed on my PC?
Yes this is true and also applies to the TT order routing as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
