Date/Time: Fri, 31 Jan 2025 18:55:44 +0000
ACSIL: Order Request Reject, Code: 73 Text: Order not found by account ID ... a
View Count: 768
[2019-05-24 20:31:45] |
TedMar - Posts: 190 |
why i get folow messeges on sc.ModifyOrder; Order Request Reject, Code: 73 Text: Order not found by account ID 16855788 and order ID 990122749. | 2019-05-24 22:05:36.054
this is not used Account and sure not Remembered Order ID.or sc.CancelOrder Order Request Reject, Code: 1 Text: The order to be canceled was not found. Order Cancellation failed | 2019-05-24 22:09:23.384
Cancel Order EXAMPLE // in example is Manual Loop and sc.UpdateAlways = 1; // orderes are placed or changed direct on the fly without any Close status on connected datafeed if (RememberedOrderID != NewOrder.Price1) { int Result = sc.CancelOrder(RememberedOrderID); } { int Result = (int)sc.BuyOrder(NewOrder); if (Result > 0) { RememberedOrderID = NewOrder.InternalOrderID; } } maybe are changes OrderStatusCode (SCOrderStatusCodeEnum) to fast ? Date Time Of Last Edit: 2019-05-24 20:34:00
[2019-05-25 07:19:26] |
Ackin - Posts: 1865 |
on sc.ModifyOrder;
Order Request Reject, Code: 73 Text: Order not found by account ID 16855788 and order ID 990122749. | 2019-05-24 22:05:36.054 this is not used Account and sure not Remembered Order ID. This can happen to be a loop and its condition is a pointer and you call the memory address before the pointer index. There is no zero there but some number that gives you that nonsensical message. Check the initialization of all "LOOPS" to see if the condition is or not exceeded |
[2019-05-25 14:43:39] |
ForgivingComputers.com - Posts: 992 |
Unless the RememberOrderId is being set somewhere before this line, the value is going to be unknown. if (RememberedOrderID != NewOrder.Price1)
Not sure why you would compare an OrderID number with a Price. You are trying to cancel an order with a number that has no meaning. |
[2019-05-26 03:10:57] |
In regards to post #1, that is not a Sierra Chart error. It is coming from an external trading service. You must contact your trading service about that.
