Date/Time: Mon, 21 Apr 2025 16:07:43 +0000
New Global Symbol Setting to specify dates to exclude from chart
View Count: 1015
[2019-05-24 16:01:19] |
User796776 - Posts: 95 |
I am running v1919 and am not able to get the New Global Symbol Setting to specify dates to exclude from chart to work. I have entered my date in the format YYYY-MM-DD (2019-05-20) and then performed a reload and recalculate on the charts but the date is not removed. Additionally, is there a specific separator for using multiple dates? |
[2019-05-26 03:43:50] |
This will be solved in the next release . We thought we tested this but it may have only been with Historical Daily charts. The delimiter is simply a comma character.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-26 03:44:05
