Date/Time: Fri, 31 Jan 2025 19:00:43 +0000
last traded size
View Count: 659
[2019-05-24 14:47:33]
qiw4u23oi4u234 - Posts: 34
http://www.sierrachart.com/image.php?Image=1558709065550.png
I thought the number on the right side of the sell column is supposed to represent last traded size, i.e. number of contracts that just hit market. However, I am only seeing ones and twos - which is far less that what is needed to move prices in the e-mini.
What can I do to fix this?
Thanks,
imageES-201906-GLOBEX #1 2019-05-24 10_00_13.468.png / V - Attached On 2019-05-24 14:42:36 UTC - Size: 58.72 KB - 253 views
[2019-05-24 21:38:36]
The only thing we can say is that is accurately reported based on the actual trading from the data feed you are using. Which is the Sierra Chart Exchange Data Feed. It would make sense that you are going to see small lot sizes most often.
