Date/Time: Sat, 01 Mar 2025 15:24:41 +0000
Why did my market depth become so deep?
View Count: 1085
[2019-05-24 22:15:00] |
John - SC Support - Posts: 38292 |
It is just Sierra Chart. We have increased the number of Market Depth Levels that are displayed for some symbols. You will find more information on this topic within this Sticky Support Post: 200 Levels (Now 300!) of Market Depth with Sierra Chart Exchange Data Feed Note the option to control the number of depth levels actually received in the data feed. This is controlled by the setting found at Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Max Depth Levels. You will find the documentation on this setting here: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels And yes, they are accurate, as it is what is reported by the exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-26 16:47:01] |
Regarding the accuracy, yes they are accurate.
[2019-05-27 20:50:07] |
WarriorTrader - Posts: 245 |
Hello, I have "Max Market Depth Levels" in my Data/Trade Service Settings set to 3 but there is no effect on the Depth Levels displayed. I am using CQG Web API. Thanks, WT Date Time Of Last Edit: 2019-05-27 20:51:13
[2019-05-27 22:47:08] |
Refer to that setting in the documentation. It does not apply to any services other than Sierra Chart market data services which you do not use.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-27 22:47:22
