Date/Time: Fri, 31 Jan 2025 17:59:58 +0000
[Programming Help] - ACSIL Entry/Exit/Total efficiency values
View Count: 783
[2019-05-24 03:04:30] |
User553714 - Posts: 184 |
Hi, Could you please consider adding the Entry/Exit/Total efficiency values seen in the Trade Activity Log as members to either the struct s_ACSTrade or struct s_ACSTradeStatistics? I had a look in scstructure.h file and I don't believe they are currently there; is there somewhere else I can access them from using ACSIL? Thanks |
