Date/Time: Wed, 08 May 2024 12:51:21 +0000
Symbol specs
View Count: 1081
[2019-05-24 01:28:26] |
cmb999 - Posts: 211 |
HN?## | SGX FTSE China A50 - SIMEX is listed as quarterly, when it is monthly expiration https://www2.sgx.com/derivatives/products/chinaa50?cc=CN#Contract%20Specifications |
[2019-05-25 15:47:58] |
N225-201906-OSE.JPN-JPY-1000 on Interactive Brokers listed as tick size = 5 should be 10, https://www.jpx.co.jp/english/derivatives/products/domestic/225futures/01.html |
[2019-05-26 17:03:03] |
These changes have been completed.
[2019-05-27 18:31:37] |
mini-Topix, MTPX-201906-OSE.JPN-JPY-1000 should be, MNTPX-201906-OSE.JPN-JPY-1000 https://contract.ibkr.info/v3.10/index.php?action=Details&site=GEN&conid=356303140 Date Time Of Last Edit: 2019-05-27 18:31:53
[2019-05-27 21:13:16] |
This has been corrected. It is recommended that you update to the current version to get the updated symbol settings and have the old symbol replaced with the new symbol. Otherwise, you would end up with two symbols in older versions. Updating instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-19 00:46:14] |
Palladium futures tick size should be 0.1 not 0.05 https://www.cmegroup.com/trading/metals/precious/palladium_contract_specifications.html |
[2019-06-19 14:07:55] |
This has been corrected. Apparently the exchange made a change.
[2019-08-18 15:35:57] |
request to add FESB Stoxx Banks (eurex), https://www.eurexchange.com/exchange-en/products/idx/stx/esf/EURO-STOXX-Banks-Futures-947318 Date Time Of Last Edit: 2019-08-18 15:36:52
[2019-08-19 00:15:20] |
We will get that added.
