Date/Time: Fri, 31 Jan 2025 17:42:51 +0000
[Programming Help] - Spreadsheed formula for entry
View Count: 583
[2019-05-24 15:56:54] |
ForgivingComputers.com - Posts: 992 |
If you are using the Spreadsheet formula study, add a formula in the study settings that evaluates to 1 for entry. The formula uses the same syntax as an alert formula. If you are using a spreadsheet study for trading, you need to put a formula in cell K3 that evaluates to a 1 when you want to enter long. M3 for short. Date Time Of Last Edit: 2019-05-24 15:59:07
