Date/Time: Fri, 31 Jan 2025 18:00:21 +0000
[Programming Help] - How to migrate SierraCharts from one computer to another
View Count: 1895
[2019-05-23 14:17:46] |
Marc P - Posts: 29 |
I have SierraCharts installed on two computers. It is running fine on my backup computer but it is not running properly on my main computer. My Emini Zone Studies are not loading on my main computer since Tuesday. How can I remove all of the SierraChart files on my main computer and install the files from my backup computer onto the main computer? I have tried everything I possibly can to fix the problem on the main computer but I cannot do it. |
[2019-05-23 22:59:48] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation We recommend though copying Sierra Chart into a different folder on your main computer so you do not affect your current installation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 23:00:45
