Date/Time: Fri, 31 Jan 2025 17:59:00 +0000
Sessions time set up for Moscow
View Count: 1268
[2019-05-23 07:46:51] |
Vladislav Kravchenko - Posts: 39 |
Hello, would you please tell me what are the settings for "Start time" "End time" should look like if my time zone is in Moscow? Also, is that correct if I put "Moscow / +4" in time zone ? Also I have an issue with prices. Yesterday (22.05.19) I was trading NG future and at that time the price of fill of position was 2.619, but today is another contract of NG and the prices on the graph on 22.05.19 are absolutely another! How is that possible? |
[2019-05-23 23:04:29] |
First, the Start Time and End Time are dependent on the particular symbol that you are trading. For the NG futures, the following website shows the Start Time as 6:00pm and the End time as 5:00pm Eastern US time: https://www.cmegroup.com/trading/energy/natural-gas/natural-gas_contractSpecs_futures.html In Moscow, you would enter those times as Start Time: 01:00 and End Time: 23:59:59. Refer to the Time Zone information here: Time Zone Setting Second, if you were changing your time zones, then the data at the same time will be different, as the time zone will change the time for a particular bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
