Date/Time: Fri, 31 Jan 2025 17:41:16 +0000
Relative Volume study ignores Value Format setting
View Count: 564
[2019-05-22 16:50:03] |
User972768 - Posts: 166 |
Hello, Small issue here with Relative Volume study. If I set Volume Format dropdown to "Large Integer With Suffix" it shows float instead. Please find attached screenshots. If numbers are too low (even to add K suffix), they should be integer. Thanks and best regards Date Time Of Last Edit: 2019-05-22 16:54:08
RelativeVolume_chart.png / V - Attached On 2019-05-22 16:49:42 UTC - Size: 12.54 KB - 232 views RelativeVolume_settings.png / V - Attached On 2019-05-22 16:49:49 UTC - Size: 41.42 KB - 229 views |
