Date/Time: Fri, 31 Jan 2025 17:49:27 +0000
Bar update delay
View Count: 605
[2019-05-22 14:18:55] |
User25309 - Posts: 19 |
I've noticed the current bar on some of my charts isn't changing with price. Meaning, the price is changing, so I'm getting the data from my feed, but the bar changes with a delay of several seconds causing it to jerk up or down to meet the current price.
[2019-05-22 16:11:17] |
We see you are using Interactive Brokers . So make sure you are not using the true real-time data: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-22 16:18:54] |
Thank you, that solved it. I thought it was strange that only the chart for RTY was working properly. |
